Next generation 8300 adds DVD burner - Canadian TV, Computing and Home Theatre Forums
Old 2005-04-04, 12:50 AM   #1
technut
Location: Victoria, BC (on Shaw TV & Internet, Telus home phone, Bell mobile)
Post Next generation 8300 adds DVD burner
Scientific-Atlanta will expand its set-top leadership position with innovative new DVR with DVD
Building upon its award-winning Explorer(R) 8300(TM) digital video recorder (DVR) platform, Scientific-Atlanta today announced its new MCP-100(TM) Media Center DVR with a built-in DVD burner. This market-leading product will combine all of the great features of the current Explorer 8300 platform, including multi-tuner DVR, optional high definition DVR, DOCSIS (DSG) and Multi-Room(TM) DVR capability, with a new built-in DVD player and burner.
The MCP-100 Media Center is currently scheduled to be available Q4 CY2005.
Mike / technut
technut is offline
Old 2005-04-04, 06:29 AM   #2
mfabien
Article says:
" The new MCP-100 Media Center will add DVD burning functionality for
standard and high definition content that will give consumers the ability to
simply and securely record their favorite shows and movies onto writeable
DVDs."
Asking SA to advise if burning a DVD with HD data gives an HD or SD playback. Not sure present technology would allow burning in HD.
Will advise...if SA replies.
Samsung LN52B750, SVS PB12-ISD, Harmony One, HD-A1, BDP-1400, Oppo DV-970HD, Zektor HDS4.1
mfabien is offline
Old 2005-04-04, 10:28 AM   #3
JohnnyG
Geez, SA...how about giving us working Firewire ports so we can use what we already have before you spend time working on something like this?
JohnnyG is offline
Old 2005-04-04, 10:55 AM   #4
darrylr
I thought the firewire ports physically work already but the firmware Rogers gives us doesn't not have them enabled.
Am I wrong?
-Darryl
darrylr is offline
Old 2005-04-04, 10:57 AM   #5
JohnnyG
AFAIK, the Firewire ports don't work on any 8300HD anywhere.
JohnnyG is offline
Old 2005-04-04, 11:06 AM   #6
Wayne
There is nothing stopping one from burning a DVD-ROM disc with HD material that is encoded with MPEG-2, WM9, DivX or whatever but these will not play in DVD players, just in PCs. However it is unlikely that this box would do this.
It would be nice if these SA boxes also acted as media portals that connected to your LAN and allowed you to view movies and photos from your LAN and play music from your LAN, just like my Gateway Connected DVD player.
Wayne is offline
Old 2005-04-04, 11:08 AM   #7
darrylr
If that is the case there must be some bigger reason why it isn't working yet other than they haven't coded it? I wouldn't think the code for that would be very complicated.
Maybe some powerful US Movie or TV associations/companies don't want it enabled just yet?
-Darryl
darrylr is offline
Old 2005-04-04, 11:12 AM   #8
RRH
Agreed Johnny G
Not having any access to OTA signals in My area, I would sure like to see working firewire ports, or barring that to have the ability to have both
the DVI Output & the component OUT outputs able to both function at the same time that would be just as good for me. Then I could go DVI to the TV
and Component out into my Pinnacle DV box into my PC. If I could ever get
that setup working I would be Buying a new HTPC real Soon.
RRH is offline
Old 2005-04-04, 11:15 AM   #9
Wayne
Originally Posted by RRH
Then I could go DVI to the TV and Component out into my Pinnacle DV box into my PC. If I could ever get that setup working I would be Buying a new HTPC real Soon.
But can you actually digitize the signal coming from the component cables. I don't think that is possible without spending 10's of thousands of dollars, is it?
Wayne is offline
Old 2005-04-04, 11:48 AM   #10
RRH
http://www.tigerdirect.ca/applicatio...883&CatId=1424
Sorry Wayne
My Mistake MY pinnacle box will only do Composite or Firewire, But my new box
the ADS one above does have component in, I am just not sure if it could handle The HD data rate, IT will do component out(480p) from a DVD player
I have hooked up to my Video editing PC Into the PC through Firewire With NO problems though so I am Hopefull at this point that could Do IT. I should
hook up my LG upconverting DVD Player up to it and Give IT a shot at 720p
and see if it works ok, I have a idea it will work alright.
RRH is offline
Old 2005-04-04, 12:08 PM   #11
lcohen999
what about this Multi-Room(TM) DVR
We have a DVR downstairs and there is always a fight to watch what was recorded, will this ever make it to prime-time?
lcohen999 is offline
Old 2005-04-04, 03:53 PM   #12
electronics_tech
Thumbs up
You can burn a disc with HD material and then there is lots of software that will allow you to convert to a playable DVD format for all standalone players.
electronics_tech is offline
Old 2005-04-04, 04:16 PM   #13
BSmithern
...or you can buy the $79 Phillips DVP642 player and simply playback the DivX or MPEG2 files straight up without any conversion. I watch burned DivX files all the time on DVDRW discs without any conversion.
BSmithern is offline
Old 2005-04-04, 06:15 PM   #14
scotta
Not having any access to OTA signals in My area, I would sure like to see working firewire ports, or barring that to have the ability to have both the DVI Output & the component OUT outputs able to both function at the same time that would be just as good for me.
On an SA8300HD (at least on mine) you can have both the HDMI and component outputs (and also the S-video output) active all at the same time. The only catch is that when an HDMI cable is connected to the 8300, it must be active for the the other two outputs to be active. This means that you have to have something (usually a TV) hooked up to the other end of the HDMI cable, and it must be powered up so it can negotiate HDCP and whatever else is required for the HDMI to work. Otherwise, just an error message is output on all the outputs.
scotta is offline
Old 2005-04-05, 09:55 AM   #15
RRH
Cool Scotta
I will Have to check into that, I am using a SA3250 HD box and when
the DVI Is connected the analog component connection is disabled
Also FYI I tried to run an upconverted 720P signal through the ADS
AV link box from the LG, ITS a NO GO doesn't work at all 480p is fine, according to ADS
the max resolution of the curret chip is 720X480, They said the A/D
converter chip
is capable of handling the HDV 720p tranfer rate
and the 1080i transfer rate but the current converter
chip cannot handle the 4 /5 Times higher bitrate of of the HDV or HDTV
stream at this time. It worked some what but was dropping frames like
crazy, and at 480P it never drops an frame I can capture for hours at a time
usually without any frame loss.
RRH is offline
