Datacolor SpyderTV - Calibration. - Canadian TV, Computing and Home Theatre Forums
Old 2005-03-28, 02:50 PM   #1
Default Datacolor SpyderTV - Calibration.
Read about this in Popular Science. They said US$250. Anyone used it?
http://spyder.datacolor.com/spydertv_usa.shtml
57 is offline
Old 2005-10-10, 10:57 PM   #2
spy604
anyone try this yet?
spy604 is offline
Old 2005-10-11, 09:39 AM   #3
Jake
Looks interesting. Too bad these systems don't work on front projectors. It would be nice if your local AV store rented the system.
Jake is offline
Old 2005-11-21, 01:02 AM   #4
spy604
Default just ordered one off of ebay`
I just ordered one of these off of ebayll, i'll post my comments once i get it.
spy604 is offline
Old 2005-11-21, 07:59 AM   #5
Biggworm
I have purchased two of these from Vistek.ca for the Graphic design / Publications department where I work. I've seen what they can do for high end PC monitors (CRT) and it was impressive. Never thought of trying it at home. Guess what I'll be borrowing from work today?
Luceo Non Uro
Biggworm is offline
Old 2005-11-21, 08:03 AM   #6
painter
Was watching HDnet the other day and they had a show about what's hot at the CEDIA 05 show,the Spyder was mentioned on their,as what's new in the home calibration front.Talked about it a bit and basically showed how it worked.
painter is offline
Old 2005-11-21, 08:35 AM   #7
eljay
Premium Supporter
From the brochure for the Spyder:
Virtually all-home theater displays offer visual menu adjustment sliders: Brightness, Contrast, Color, Tint, and Color Temperature Presets. However, they rely on the viewer’s eye to determine whether the settings are correct. This can lead to inaccuracies because people see color differently. The perception of color changes based upon lighting, seasons and other subjective conditions. Datacolor SpyderTV has fully automated the process, applying scientifically-based adjustments to each control in order to achieve more accurate results. It’s the next best thing to hiring an ISF certified calibrator.
$250 USD to adjust sliders in the user menu? I must be missing something, particularly since calibrators do more than that.
MY HT SET-UP (PICS & GEAR LIST)
eljay is offline
Old 2005-11-24, 03:03 PM   #8
distox
The most important function of the Datacolor SpyderTV is to calibrate grey scale. With a proper grey scale, colors will look correct. Skin tones will look like real skin. Not too green or too blue or too red. Also dark scenes will have details and look black, no color tint where there shouldn't be any.
Home is where the Theatre is!
distox is offline
Old 2005-11-24, 03:55 PM   #9
The only way to properly do greyscale is in the service menu, usually with a Sencor unit. Although the "sensor" on this unit is similar, if not identical, I'm not sure it allows for service menu settings in the software on the PC... The unit is mainly for user settings and should give you good PQ, except for that final service greyscale step.
It's almost like using AVIA, without relying on your eyes, the sensor does the checking.
57 is offline
Old 2005-11-24, 04:42 PM   #10
spy604
Default just got my spiderTV
Just got my spyderTV unit.
I'm certianly not a home theater expert but the whole setup and "calibration" procedure whas pretty straight foward, i defeinetly noticed a PQ improvment while playing video games (perfect dark zero on the xbox 360).. Hard to say if it was worth the cost, but soon i'll have 3 HD TV's and it will be cheaper to use this than get a real Pro in to calibrate my sets.
I have a 34inch Toshiba CRT widescreen TV, but i'm planning to pickup two new big HD sets in the next couple of months.
spy604 is offline
Old 2005-11-24, 04:47 PM   #11
grog
Out of curiosity, how much did the one off of eBay cost you? Was the seller in the U.S. or Canada?
thx
grog is offline
Old 2005-11-26, 01:05 AM   #12
spy604
thx
It cost me 221.85 USD with shipping and insurance and about $40 CDN for customs.
spy604 is offline
Old 2005-11-26, 10:14 AM   #13
hoju_17
I listen to the "HDTV and Home Theater Podcast" that is put on by two guys from avsforum.com and they reviewed one of these. I think the review was in episode #40. They gave it a good review if I remember correctly.
hoju_17 is offline
Old 2006-01-05, 02:45 PM   #14
I bought one of these from a "friend". It works very well and is very quick.
http://www.colorvision.com/spydertv_usa.shtml
The entire "calibration" took 36 minutes (for my first one) and there is no "guesswork" on contrast, brightness, colour, tint and colour temperature.
The unit helps you to optimize these user settings. It doesn't do service menu settings or sharpness.
Good product.
http://www.audioholics.com/productre...erTVreview.php
The above report talked about "repeated requests". I also encountered this, but only once (not 4 times like they did). I simply assumed that the device didn't get the "reading" quite right. I did not find the unit "favours red". (My TV recently had a pro calibration)
57 is offline
Old 2006-01-05, 11:29 PM   #15
Sam
I actually wanted to buy this about 2 weeks ago to calibrate my monitor I use for processing my digital photos. I had second thoughts, but after reading your positive comments, I might just drop by Henry's one of these days and get myself a copy especially now that I have this awesome Hitachi plasma TV.
Sam is offline
