Copy to VCR and DVD Recorders? - Canadian TV, Computing and Home Theatre Forums
Old 2005-03-27, 08:34 AM   #1
Mikehami
Question Copy to VCR and DVD Recorders?
I have an 8300HD and have discovered the Copy to VCR function that seems to work fine. The output is through the composite out2vcr output of the 8300, into the composite in of my VCR. I now see that there is a DVD recorder available at FS for under $300. Does the Copy to VCR work with the DVD Recorder too? If so, what are the considerations re how much time can be stored on the DVD, in what resolution, etc., etc. I don't know much about the technical aspects. I really just want to archive a few movies from VOD and a few non-HD and HD TV shows (Rogers). Thanks. Any guidance from those of you who are experienced with this would be great!
Mikehami is offline
Old 2005-03-27, 10:17 AM   #2
madness
Mikehami
i have a panasonic hdd/dvdr hooked up to my 8300 thru s-video. the copy to VCR works great. you can even watch other stations while its coping to your dvdr or you can even turn off your tv and cable box and it still sends the signal to your dvdr.
other's can correct me here...
but I think with minimual loss of quality, you can get 2 hours onto a standard dvd. the resolution is better if you use the full dvd to record only an hour but i haven't seen much difference (of course this all depends on your dvdr). my pvr/dvdr has different settings similar to vcrs ie sp lp ep... so you can get 6 hours or more on a standard dvd but then the quality goes down (again this is probably all dependent on your dvdr). one nice thing about mine is it also has a "fit to" setting so it records the best possible quality depending on the length of the show.
madness is offline
Old 2005-03-27, 04:35 PM   #3
I've read that as soon as you go "past" the 2 hour speed, the quality drops to that of a VHS tape. Since DVD is digital, the only way to get the additional recording time is to "drop" every second line once you go to the 4 hour mode. So, for high quality - the first two modes are usually best.
57 is offline
Old 2005-03-27, 05:04 PM   #4
andrew.r
I have been interested in archiving some of my recorded shows to DVD and have not been interested in "Copy to VCR" since I do not have any interest in my VCR any longer. I did not know that it is possible to "Copy to DVD" using the "Copy to VCR" function. Will it work when connected via component to the DVD recorder? Wonder why Rogers always told me you cannot copy to DVD???
andrew.r is offline
Old 2005-03-27, 05:27 PM   #5
There are no consumer recording devices with component video HD inputs. You'll need to use composite or S-video for the DVD Recorder.
The copy to VCR used to be disabled, perhaps that's a cause of confusion at Rogers, but usually, many CSRs are simply unaware of the myriad of features that the various STBs have.
57 is offline
Old 2005-03-27, 05:30 PM   #6
JesseJ
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
I used the slowest speed (1 hr.) to record an HD version of Carnivale to DVD. My gf commented on how it looked like a DVD quality movie. Actually, it almost is, as it's sent out in 480i via composite, and recorded accordingly, in 480i. We watched it back on a non-prog. DVD player, and it was stunning.
I'm not sure about the Rogers boxes, but the Moto 6412 will NOT send a 16x9 signal out the composite, so everything is presented in letterbox form (4x3).
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld)
JesseJ is offline
Old 2005-03-27, 05:34 PM   #7
Composite Video usually is only capable of about 400 lines (horizontal). You may wish to use S-video for 20+% better quality.
Rogers STB sends out the 16:9 image (letterboxed "inside" 4:3).
I have heard of some STBs that send out "anamorphic" images (I believe *C).
57 is offline
Old 2005-03-31, 10:46 AM   #8
Rick
Location: Toronto, Ontario (Rogers, Oppo 103, Sony S590, Denon 2809, Panasonic AE3000, Carada 2.35 120 in.)
The Sony RDR-HX900 uses variable bit rate recording when something has been recorded onto the hard drive at HQ or HQ+ and is dubbed to a DVD at a lower resolution. So, for example, I can record a 3 hour show in HQ to the HD, then dub at LP mode and the result looks pretty good. Of course, that unit is rather expensive!!!
Rick is offline
Old 2005-04-02, 08:30 PM   #9
Mikehami
Question Hooking up 8300HD PVR to DVD Recorder LGR435?
I am considering getting a LG LGR435 DVD Recorder to hook to my 8300HD PVR, so I can copy a recorded TV show to a DVD. I am told that I can use the Copy to VCR option of the PVR. The normal output from the 8300 is via the 3 composite2 connections to the composite inputs of the VCR. My question is can I use the S-Video out on the PVR to the S-video in of the LGR435 for the video signal, to get better resolution than the composite video connection? Has anyone done this, and what is the improvement in the video resolution? I presume I would still use the R and L audio connections as before. Thanks for the help.
Mikehami is offline
Old 2005-04-03, 10:55 AM   #10
Rick
I use the s-video connection on my 8000HD -- I assume it would also work on the 8300. I have never compared the quality with composite.
Rick is offline
Old 2005-04-03, 02:02 PM   #11
scotta
Yes you can. The S-Video out will switch to the VCR output signal when you invoke a copy to VCR.
And, yes, you would still use the R and L audio connections (Out 2).
scotta is offline
Old 2005-04-03, 02:10 PM   #12
JesseJ
With the LGR435, the S-vid connection is on the front of the recorder only, there is no rear s-vid input. It's a good machine, but depending on your STB, you will get a 4:3 letterboxed picture, not an anamorphic. You can always use the zoom on your TV, or the zoom on the player to get rid of the bars when you play back. Recording from cable produces good results, as well as via composite from the STB.
JesseJ is offline
Old 2005-04-03, 03:55 PM   #13
http://digitalhomecanada.com/forum/s...47&postcount=2
57 is offline
Old 2005-04-03, 04:17 PM   #14
Splash
Originally Posted by 57
There are no consumer recording devices with component video inputs. You'll need to use composite or S-video for the DVD Recorder.
HUH ? Are you sure about that?
http://www.amazon.com/exec/obidos/tg...88927?v=glance
Splash is offline
Old 2005-04-03, 05:18 PM   #15
It also includes a component-video input, which offers a high-quality analog connection to turn your collections of VHS tapes into higher-quality digital recordings.
What VHS tapes output on component video?
I have no idea what the use is for this input, but I seriously doubt it's for anything HD.
Some STBs have CV inputs which are used as a "passthrough", which then mean one less connection required on the TV... These inputs are limited to 480i on consumer devices.
I've changed my previous post to "component video HD inputs"
57 is offline
