Hitachi & Other Manufacturers Convergence Problems (STK392-110 ICs) Read Post 1 - Page 52 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2012-03-29, 02:39 AM   #766
saeia
Oh ok so there is no danger of radiation from RP guns? Thats great news.. just kinda feels like i got burnt on the inside like an xray.. maybe its just radiation.. now i just hope someone else can help with the angle issue ^^
saeia is offline
Old 2012-03-29, 09:52 AM   #767
saeia: I've moved your post to this existing thread on convergence issues. Please read post one of this thread thoroughly and carefully. All the information you need is there as it has been distilled from years of posts here.
You don't have radiation, but as mentioned in post 1, there is high voltage in these TVs and you could be dead!
57 is offline
Old 2012-03-29, 12:13 PM   #768
cambo
Saeia
These TV's are not meant to be opened by the untrained. If you're not sure what you're doing, you're best to close it up and contact a qualified service person.
The only part meant to be replaced (sometimes) is the bulb. Anything else and you're asking for trouble. Not from "radiation", but from the high-voltage capacitors. You can easily further damage the TV, or yourself.
cambo is offline
Old 2012-03-29, 12:25 PM   #769
The topic of this thread - CRT-based RPTVs - don't have bulbs.
57 is offline
Old 2012-03-29, 12:39 PM   #770
cambo
The point is, he's putting himself in a lot of danger by opening the cabinet. Not whether a bulb can/should be replaced.
cambo is offline
Old 2012-03-29, 12:40 PM   #771
Thank you for pointing that out. That point is also covered in huge letters in post 1 of this thread. It's probably also printed on the access panel(s) of the TV itself.
TVs that have replaceable bulbs (like DLP, LCD, LCoS RPTVs) have them in separate sections that can be handled by most handy people, but that's the topic of another thread.
57 is offline
Old 2012-03-29, 04:53 PM   #772
saeia
57, Thanks i will read this thread And i know full well about the dangers of capacitors. I've been a pc tech for almost 10 years now and i've replaced many capacitors. Never worked on anything this big but i understand the dangers.
saeia is offline
Old 2012-05-01, 10:56 PM   #773
rrayfrmcal
Default Diff symptoms - same problem?
Hi 57,
You've done great work all these years on this thread helping hundreds of folks save a bunch of cash. Thanks.
I have replaced the IC's twice in the past and each time they lasted about 3 years. On those occacions the symtoms were convergence related. The set just went out again but this time there is no picture and you only get the sound to work if you press the channel button? The model is a 60SDX88BA, yea I know it's old but it still had a great picture.
Thanks for the help.
Rick
rrayfrmcal is offline
Old 2012-05-01, 11:36 PM   #774
Here's a list of things to check/try. Can't help much beyond that. Do you get a flashing light error code (a certain number of flashes)? If so you can ask an Hitachi technician what the code means.
http://www.digitalhome.ca/forum/showthread.php?t=19694
57 is offline
Old 2013-02-26, 04:44 PM   #775
srfrdudeo7
Exclamation HELP! with Hitachi 43fdx20b
I ran magic focus and after I did that this came up ? what could this mean?
http://tinypic.com/r/bec3g0/7
srfrdudeo7 is offline
Old 2013-02-26, 04:50 PM   #776
Your post was moved to this existing thread. You likely have an issue with the convergence ICs or something else in the convergence circuitry. Read post 1 of this thread thoroughly and carefully. Since your TV is over 10 years old, it's probably not worth getting it fixed unless you wish to tackle it yourself. 40-50" TVs are pretty inexpensive these days and would have much better picture quality.
The overflow condition can arise also when doing a manual (or DCAM) convergence - link in post 1, but I'm not sure that's available for your model - check the operating manual for convergence options.
Here's a post useful for those new to the forum - FAQs, Search Tips, Optimization, etc:
57 is offline
Old 2013-03-13, 01:00 AM   #777
wrencher
Default got 5 minutes, now it chirps
My 12+ year old 43fdx01b finally took a nap last week. Never ever seen the repairman. Was working downstairs and TV was on with nobody watching. when I finally looked at it I noticed a red color misalignment.
Hit the convergence button and noticed a wavy/occilating vertical convergence issue. Next step: service convergence (blue button).
In the past I've gotten away with hitting power while holding input on remote. (saves having to open front panel). Got an image almost identical to post #543
http://i35.tinypic.com/25993f7.jpg
Horizontals were good but vertical same as pic and occilating/flutter left/right about
.5 inches. Tried moving convergence, but was unsuccessful-would start to move then spaz out or move wrong direction. Powered down opened front panel and retried with blue button...same!
Indexed and tried adusting rings on red crt- no good. In ignorance fiddled with
focus/screendrive- dumb.
That's when I found this forum and ordered the "repair parts". Got the latest: stk394-160e and the 6 resistors as per bulletin. Even though none were out of spec.
changed the parts and when I turned on almost same exact image as before,
didn't seem to occilate/flutter though but set is cold. Went ahead and tried adjusting convergence. kinda/maybe seemed to work. Was getting in within ballpark or was it my illusion.
when puff- screen went out and faint chirp chirp chirp coming from rear d.e.f power supply area. I think behind 2 large caps or transformer area. red led also pulsing with chirps. If i unplug power feed to board the chirp stops.
Any ideas? Seen this problem before?
Pulled the board again and rechecked every solder joint and for any "burn't or discolored resistor". also around board...and for cold solder joints. Can't find squat.
I would find it strange that the chips had and rehave the exact same prob/symptome.
Could it have been a weak power supply prob that finally blew with the new chips? (think I read they are rated higher amp)
Would greatly appreciate any input on this issue.
re: I know its an old set and I have a new flat being delivered hopefully tomorrow.
But I like this old dinosaur and would like to shove it in the gameroom. 4X3 still rock in my opinion.
wrencher is offline
Old 2013-03-13, 02:43 AM   #778
wrencher
anybody have any ideas where i could find a copy of the service manual for
hitachi 43fdx01b. hopefully free as tv is very old and worth nada.
wrencher is offline
Old 2013-03-13, 10:30 AM   #779
Searched the web for "Hitachi 43FDX01B Service Manual" and found several links. Here's one: Good Luck with your repair.
http://www.s100-manuals.com/529598--...i_43Fdx01B.htm
57 is offline
Old 2013-03-13, 10:40 PM   #780
wrencher
Update, I checked a few resistances on the board and decided to swap out one of the 2 chips (i chose the red ctrl), 50/50 chance that if it was a bad chip, tv would turn on when i swap it. and 50/50 chance if one of the old original chips was blown i'd not grab it.
well tv back on ....but convergence spazed out again. maybe tomorrow i'll swap the red chip again and see if there is a difference. it's either that or a DCU problem i figure- I hope that my messy convergence is not something i caused. Wish I had the later set with auto convergence set .
If it wasn't that i don't know for sure that this is the problem i'd pick up some 150 series on friday.
wrencher is offline
