If you are using a One-For-All or Radio Shack remote, you can program a button on the remote to quickly skip through commercials:
1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode. 2) Press and hold the "Setup" button until the LED blinks twice. 3) Type in the code 994. The "Cable" button will blink twice 4) Press (do not hold) the "Setup" button 5) Type in the code 00173 (for 30 second Skip) 6) Press whatever button you want to map the skip Depending on the model of your remote, instead of code 00173 you may need either 0173 or 173. This feature is not implemented on the Motorola remote due to pressure from advertisers (those bastards!) These remotes are cheap and can control every device out there. See http://www.hifi-remote.com |
On my Kameleon 8-in-1 it's:
Press-hold "Setup" until the setup "button group" comes up Press "Other" Type in "994" on the number pad that appears Hit "Cable" Press (don't hold) "Setup" Type "173" on the number pad Two flashes (after a bit) means it worked. Press "Home" to get back to the programming screen Press "Home" again to exit programming, or back to step 2 to continue programming other buttons. I use "0476" for my base setup, and then use that procedure to add the additional buttons: http://www.hifi-remote.com/cgi-bin2/ueic.cgi?cbl_0476 |
Thanks for the information, but a simple search would have found several previous threads on the subject. Some Motorola remotes do have the feature. See below:
http://www.digitalhomecanada.com/for...earchid=148099 (Sorry, link now dead, see post 12)
Understood, but at the same time it's info that might be valuable to someone new - who has no idea that the function exists, let alone searching for it.
Everything I've read about the 6412 on other sites has been shaky, mainly because it wasn't written specifically for Eastlink users. There's a difference between telling someone to "do a search" when they ask a FAQ ('How do I add the 30 second skip button to my remote?") - versus someone going ahead and taking the time to document something ("There is 30 Second Skip, here's how to enable it!") that may be of interest to a specific forum, even if it may be redundant comapred to the other forums. |
That's why I said thanks, and that's why this thread is still open.
My comment about the other threads was to correct the original posters misconception that all Motorola remotes cannot do this... Perhaps you could ask Eastlink for the "correct" remote and not require the purchase of an additional one, unless you want an all-for-one anyway?
I'm half figuring that they'll need to come out with a new remote anyway - for the 6412 after the dual-tuner functionality is enabled. It's currently lacking some buttons, like "swap."
It's also possible, as far as I know, to enable it on the Motorola remote we have as well, via the 994 sequence. I just couldn't be bothered to figure out the sequence of presses for it specifically, and I already had a Kameleon and I was programming it for the DVR functions anyway. |
Actually EastLink uses the Motorola DRC800 remote which does have the dual tuner funtions preprogrammed in. As to why they don't have the 30 second skip function, I have no idea.
The older DRC450 remotes however do not. Not every provider using motorola boxes uses the same remotes. I can't speak for any others but Shaw uses a different brand of remote from a company called Atlas. I beleive Rogers uses the same brand of remote for both their Motorola and Scientific Atlanta boxes. |
Has anyone gotten Eastlink to supply a "correct" remote that is programmable?
If it's available, I want one! |
#9 |
#10 |
I have the DRC800 - but the only "swap" button is the PIP swap... ahh. I think I answered my own query. Two tuners make in-box PIP possible - swap, etc, yes? I was mistaking that group as buttons for my TV's built-in PIP - which it does control as well.
Does anyone know what this Motorola remote is based on? If it uses the same codes as other devices, is it safe to guess the 944 sequence might be used to make the A,B or C buttons do the skip command? |
#11 |
I think the programming given below would work with the DRC800 if it only had a SETUP button!
Has anyone been able to program the DRC800 for this 30 second skip? This is the remote supplied with Motorola's DCT6208 by Rogers NB. I found the users guide, but no mention of programming it rather than for other equipment. Am I missing something? http://commerce.motorola.com/consume...UserGuide2.pdf 57, Your link below is a dead end. Did the thread get moved or deleted?
DCX3400,Hitachi51S500,Denon3805,Oppo971H,ParadigmMon9s/CC370/MiniMons/PS1000,Harmony676 DCT6200,SammyUN46C6300,BD5500 Last edited by Lenster; 2005-04-19 at 04:15 PM. |
#12 |
Thread must have been moved. Try this one? (Looks the same as post 1 though...)
http://digitalhomecanada.com/forum/s...8&postcount=99
#13 |
Yeah, OK. This is great if you're programming some other remote, but for some reason, the Motorola DRC800 doesn't have a SETUP button, which makes it real difficult to follow the directions. The two first posts involved Kameleon and Radio Shack remotes. What do you use as a substitute for SETUP?
DCX3400,Hitachi51S500,Denon3805,Oppo971H,ParadigmMon9s/CC370/MiniMons/PS1000,Harmony676 DCT6200,SammyUN46C6300,BD5500 |
#14 |
Do an advanced search for "second skip", in "thread titles" only. I got several hits for the Motorola remote, but apparently it doesn't work everywhere?
#15 |
Shaw users seem to be able to program their Atlas 5 remotes, with & without a JP1 cable. Motorola's DRC800 is not programmable with or without the cable, or at least I have not found anyone who has done it. If you send a code 0173 to the unit, I'm sure it will do a 30 second skip, but how do you send this code and program it to one of the unused macro buttons (A, B or C) on the DRC800? There must be a way - I'll keep searching...
Thanks 57.
DCX3400,Hitachi51S500,Denon3805,Oppo971H,ParadigmMon9s/CC370/MiniMons/PS1000,Harmony676 DCT6200,SammyUN46C6300,BD5500 Last edited by Lenster; 2005-04-21 at 08:24 AM. |
