#1 | |
Location: Toronto, Rogers, SA8300HD, eHDD, Hitachi 61UWX10B, Yamaha RXV1 AVR; SA8300HD, eHDD & Sony KDL40W3000
Updated 2009.11.01
Since this applies to several cable companies, I thought I'd put it here. It's a very helpful link for those with Motorola STBs. I believe the diagnostics are applicable to Pace STBs from Shaw. http://cjhengineering.com/hdtv/cablehdtv/dctset-up.htm This first page is for "Video setup", including instructions on access to the user settings/menu, however, you can select other information from the top left. Diagnostics (for S/N Ratio, etc): http://www.cjhengineering.com/hdtv/c...tv/dctdiag.htm Other useful tips gleaned from this forum: 1. We recommend you do not turn off the 6208/6412/6416. The HDD doesn't spin down anyway, and "off" is really "standby", consuming almost the same electricity. Since the HDD buffers the channels, perhaps you can tune to a music channel before switching off your TV, this will reduce the buffering due to the lower bitrate. Edit 2007.09.28. This recommendation regarding not turning off the PVR is a bit old and some people have been able to turn it off without encountering problems, like there were a while back. Be aware that when the PVR powers itself up, the audio is muted on all outputs. That's apparently to guard against the speakers blaring in the middle of the night or something. To get the sound back, just bring up the guide or something to let the DCT know you're there. I think that's a recent firmware enhancement as it used to remain muted after powering itself up. http://www.digitalhome.ca/forum/show...610#post609610 2. If your STB doesn't "play", go to a previous recording and hit play... this may bring your box back to life. 3. If the audio mutes after using the skip button too many times, hit the last button twice and your sound will come back. 4. Reboot the STB once a month by unplugging it and plugging it back in before you go to bed. This way the IPG will be ready when you next need to use it. 5. If you're getting split recordings, lots of pixellation, or sound dropouts, check the signal strength (S/N ratio) in the diagnostics above. Also remove any upstream items such as splitters and power bars for testing. 6. If you're having problems, try a reboot as mentioned in 4. Wait for the time to display - if you can, wait for 30 minutes for some of the other features to download, etc. 7. Heat is a killer for STBs. Make sure the STB is well ventillated and make sure it's "on top". 8. If you get the 100% Full message, deleting a programme will usually get you back to the correct reading. Record a few 1 minute programmes so that you can delete them as required for this workaround. 9. In terms of setup, most people use 1080i for HD channels and 480i (usually best for SD) or 480P (if necessary due to the TV) for the 4:3 override, for the best PQ. 10. Note that when using DVI/HDMI connections, some HDTVs do not accept 480i signals via DVI/HDMI, so you need to turn the 4:3 Override to off, or try 480P. 11. If you have jerky/stuttering on playback, try changing the output format from 1080i to 720P. Changing the format seems to clear the problem. If the problem clears, then you can change back to your favourite output format again. If you have your 4:3 override set to 480i/p, then simply changing the channel from an HD one to an SD one and back (or vice versa) should also work. 12. Do you need to enter 3 numbers to change channels? Go to settings in your menu - then guide - then change channel behaviour to auto-tune. For "fast" channel changes, you can also hit a channel number followed by "OK". 13. If you can't see the full frame picture in the guide at the top right, try moving the position of the guide a bit to the left. This may bring the picture up properly. 14. Cold Cold Reboot (New Firmware): http://www.digitalhome.ca/forum/show...74&postcount=5 15. Information from the Cogeco Forum, which also uses Motorola: http://www.digitalhome.ca/forum/showthread.php?t=92865 16. If you have a purple/green colour displayed on your TV for SD channels, change the 4:3 override from 480i to 480P, or turn it to "off" and have all the signals 1080i. This is usually for DVI or HDMI connections, which can have lots of issues - see below. The same holds true if you have black/green/snowy screen, or long delays when changing formats - SD to HD channel for example. http://www.digitalhome.ca/forum/showthread.php?t=71112 17. In case you missed it in the first link of this post, in order to get into the user settings/menu, you power the STB "off" --> then press "menu" on the STB. Here's a detailed description: http://en.wikibooks.org/wiki/How_to_...rola_DVR/Setup If you have any comments or suggestions for this FAQ, please PM 57.
57's Home Theatre Please don't PM me with questions that can (and should) be asked in the forum, thanks. Personal Question? Fire away. |
Comcast 6412 manual Link - thanks to Technut.
Comcast 6412 DVR Manual (PDF, 3.8 MB) Sorry, link seems to have gone dead. If anyone finds new link, please PM me.
Shaw PVR Manual (pdf):
http://www.shaw.ca/NR/rdonlyres/6388...RUserGuide.pdf Shaw Remotes; http://www.shaw.ca/en-ca/CustomerCar...rt/UserGuides/ More Remote Codes and Manuals http://www.urcsupport.com/# Programming a Remote - Wiki: http://en.wikibooks.org/wiki/How_to_...ing_the_Remote Adding Remote Codes: http://www.digitalhome.ca/forum/show...202#post509202 More remote tips: http://tipcollection.com/wiki/index....set-top_remote
If you have a broadband connection on your computer (via cable). The following link should provide you with a general indication of the signal strength at your house.
This is good for people who don't have a STB or who have a Motorola STB which doesn't show Signal Strength. http://192.168.100.1/signal.html Signal strength above -10dB is adequate for digital channels and a S/N ratio of 35 is good. Any splitters "downstream" of where you have your cable modem connected would, of course, lower the signal strength. Some people may not get a reading. I don't know why - perhaps if you have a router, or if you don't have a Motorola modem. I understand that Shaw people may not get a reading due to Shaw's method of operating, or preference. Those people will need to use the diagnostics as outlined in post 1.
Useful button programming provided by talljak.
http://digitalhomecanada.com/forum/s...39&postcount=5
Here are some "known Issues" on the 6412/6208. Thanks to couchpotatoe for this (very long) list.
http://digitalhomecanada.com/forum/s...6&postcount=20
#9 |
Thanks to DCTGoddess for the following link - Wikipedia "How to".
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR
#10 |
Location: Waterloo, Rogers Cable, Toshiba 50HM66, Sony BDP-S350, Pioneer VSX-607S, TiVo, Kaleidescape 5U
Someone recently pointed me to this link:
http://en.wikibooks.org/wiki/How_to_...ot_Error_Codes While a good start, it is only about 1/3 of the possible error codes that you can see on a Motorola DCT. Here, then, is the complete list: General Error codes: These errors will display at boot time (in the case of a failure) or can also be seen by launching the OSD and selecting 'd 01 General Status'. Error codes display on the LED and the OSD. In the case of multiple errors, the last error logged is displayed: EP00 No error EP01 Not connected EP03 DRAM error EP04 SRAM error EP07 ROM verification failure EP08 RAM test failure EP09 Battery test failure EP11 Invalid unit address EP12 Power on self test failure EP14 GITV startup failure EP15 TSI structure corrupt EP18 Driver initialization failure Download error codes and informationals: The following are displayed on the front panel LEDs of the set-top during and just after the code download process. "| dl" This display indicates that an out-of band platform code object download is in progress. The first segment in the display is a crawling ant progress indicator, which moves one position for each segment of the platform code received. "EF" This display indicates that the flash memory area is being erased. "FP" This display indicates that the flash memory area is being programmed. "----" This display indicates that a network platform code object download has completed. "hunt" This display indicates that the bootloader is hunting for an out-of-band frequency. "Fr [number]" This display indicates that the bootloader is attempting to lock on to the frequency indicated by [number]. "Au" This display indicates that a platform code is being authenticated after it has been downloaded. The following are error codes that can be displayed if there is a problem with the download: Eb01 The platform code object failed a validation check, before being loaded into the flash memory area from RAM. Eb02 The platform code object download failed due to a time out or other failure. Eb03 The bootloader failed to erase the flash memory area. Eb04 The bootloader failed to program the flash memory area. Eb05 Invalid Frequency. The frequency specified in the download control message is invalid. If an upgrade download was attempted, the invalid frequency encountered was read from the Startup-Database. Eb06 Hardware initialization failed. Eb07 The platform code object failed a validation check, after it was loaded into the flash memory area. Eb08 This is a reserved error code. Eb09 A sanity check failure has occurred. The code execution check bit for the loader flags field was not cleared. Eb10 The start up database in NVMEM did not pass the CRC check, and was rebuilt to the default state. This error only occurs if both the primary and secondary copy of the start up database has been corrupted. Eb11 The bootloader failed to lock the out-of-band tuner. Eb12 The bootloader failed to receive a conditional access message. Eb13 The bootloader failed to receive a download control message or no matching Platform ID entry found. Eb14 An attempt to load a platform code object with the wrong object class or object type. Eb15 No matching platform ID was found. Eb16 An unexpected flash memory erasure or program was in progress at start up. Eb17 The flash memory area is not responding. Eb18 The platform code object size is mismatched. Eb19 The platform object size failed the range check. Eb20 The start up database pointer is not located within the appropriate NVMEM range, or the pointer does not lie on a 32-bit boundary. Note: A number of these error codes indicate a problem at the headend and should almost never be seen in the field. |
#11 |
Format the drive:
http://www.digitalhome.ca/forum/show...650#post569650 This is typically a "last resort" type of thing as it will erase everything on your HDD. (Remember the Format C command?)
#12 |
| Bookmarks |
| Thread Tools | Search this Thread |
