Remote Codes Shaw Motorola 6412 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2005-01-22, 04:49 PM   #1
GGopher
Default Remote Codes Shaw Motorola 6412
I have a DCT 6412 with a Toshiba 51H84C. I would like to reprogram the remote on the 6412 so that if you hit power in "Cable" mode it turns the TV off and not the Cable box.
This should be easy to do, I know how to program the 6412 to add the 30 sec skip, so where can i find the code for power off on the Toshiba TV.
Thanks,
GGopher is offline
Old 2005-01-22, 05:23 PM   #2
Sith
Location: Surrey, Shaw DCX 3400, Samsung UN46D6000, Denon Avr-1905, Paradigm CC-170, Titans, Atoms, PDR 10 v3
With past dct's it's always come with a manual for the remote and they have the codes for various brands inside.
Sith is offline
Old 2005-01-22, 10:04 PM   #3
GGopher
The book just describes how to set up the respective main categories on the remote. I would like to reprogram just the power button under the cable category to instead of turning the box off to turn the TV off.
That way you never have to change the remote out of Cable mode.
GGopher is offline
Old 2005-01-22, 10:32 PM   #4
Sith
On both my boxes I have it set up so that you hit the power button and it fires up both the tv and the dct at the same time. I never switch modes ie going from cable to tv etc. It does the same on and off function for both units at the same time when I press power.
If I understand correctly, what you are trying to do is hit power and have it just turn the tv off and leave the cable box on without going out of the cable mode. I am thinking that this can not be done as in cable mode it is a default code for the box which will get shot out as well when you hit the button.
As far as I know the only way to do this will be to have to switch from cable to tv and so on and so on.
Sith is offline
Old 2005-01-23, 12:39 AM   #5
technut
Location: Victoria, BC (on Shaw TV & Internet, Telus home phone, Bell mobile)
Found this at RemoteCentral.com for a Radio Shack remote but the coding seems similar ([P] button = Setup?)...
Copying Buttons:
  1. Although this function is called the "Key Mover," it actually copies codes.
  2. Press and hold the [P] button until the LED flashes twice.
  3. Enter the code 9-9-4.
  4. Select the device that contains the "source" code.
  5. Press the "source" button.
  6. Select the device where you want to copy the command to.
  7. Press the "target" button. The function is now copied.
  1. If you wish to clear a copied button:
  3. Enter the code 9-9-4. The LED should flash twice.
  4. Press the button you wish to clear.
  5. Press and hold the [P] button until the LED flashes twice. The button is now cleared.
Mike / technut
technut is offline
Old 2005-01-23, 11:42 AM   #6
GrBell
If you can afford a Harmony remote I would recommend it. They are expensive but worth it. No more worrying about various devices to be turned on or off, you just press "watch TV" or "Watch DVD" and it sorts everything out.
GrBell is offline
Old 2005-01-23, 12:58 PM   #7
GGopher
Thanks Technut!!
That was exactly what I was looking for, and it worked perfectly.
GGopher is offline
Old 2005-01-23, 01:48 PM   #8
funkright
Talking
Yes.. my wife LOVES me for this purchase.. Since getting it a couple of weeks ago she has become a happy woman in the living room, sans the other 5 remotes.
funkright is offline
Old 2005-01-23, 03:46 PM   #9
technut
Originally Posted by GGopher
Thanks Technut!!
You're welcome. www.remotecentral.com is a great site for all remote-related info.
Mike / technut
technut is offline
Old 2005-01-25, 11:40 PM   #10
tundramojo
I got an awesome deal on mine. I picked it up for $198 at FS and was happy to pay that. The last one they had was just snatched up by a shopper, but the guy changed his mind and put it back; I jumped all over it. It's a great product. It's beauty is in its simplicity. Well, I was told of the $40 rebate, so I thought, excellent, $158. Great deal. Well, on Boxing Day I walked into future shop to help a friend buy a new tv and what did I see as I walked in? The Harmony 659 remote on for $99! I go straight to the customer service desk to get a price protection refund. After getting a "no" answer from the first CSR, I ask for a manager. The manager agrees that I'm entitled to receive it at the $99 price since it's not classified as a "door crasher". Net price after rebate and price protection refund: $58. And I was happy to pay $198.
tundramojo is offline
Old 2005-02-13, 01:33 PM   #11
Nighthawk 1
I think I have everything hooked up correctly (tv-Pana47X54, receiver-Denon1505, shaw6412). I've programmed the remote codes for everything into the cable box remote. I am wondering if it is necessary to have to press the audio button first to change volume, then if I want to change channels have to press the cable button? This is what I am doing now and it seems a bit ridiculous. Would the Harmony remote be able to do this without having to select the input device first? Would it be able to do the listings search on the cable box as well? I was hoping the 6412 remote would be smart enough to know that if you hit the audio button to use the default audio device without having to select it first. Maybe I have something set wrong.
Nighthawk 1 is offline
Old 2005-02-13, 01:54 PM   #12
technut
Originally Posted by Nighthawk 1
I am wondering if it is necessary to have to press the audio button first to change volume, then if I want to change channels have to press the cable button?... I was hoping the 6412 remote would be smart enough to know that if you hit the audio button to use the default audio device without having to select it first. Maybe I have something set wrong.
Check page 32 of the manual that came with the 6412 remote, it describes how to change the volume controls so that they are locked to a particular device no matter what mode the remote is in.
The example in the manual is a bit confusing because at the top of the page they discuss locking it to the AUD device but then the steps lead you to lock it to the TV device. In step 3 just hit the key for whichever device it is that you want to control your volume on.
Mike / technut
technut is offline
Old 2005-02-13, 04:55 PM   #13
Nighthawk 1
Thanks Technut (from a fellow Victorian), that helps a lot. I have so many manuals and remotes to sift through at the moment, I'm a bit overwhelmed. In my younger days I used to be able to keep up with the technology but find myself starting all over again. Another question if I may; what settings for audio out do you use on the tv? I've got mine set for fixed audio (no tv speaker), is this correct?
Old 2005-02-13, 05:05 PM   #14
Bluecruzer
Re Harmony...
Costco has them as well... (where I got mine)... Awesome remote... plus all the keys are backlit.
You can "learn" functions online as well. Much simpler set up.
One thing for certain... none of us are getting out of here alive...
Bluecruzer is offline
Old 2005-02-13, 07:32 PM   #15
technut
That sounds right for what you are doing (cable box to TV to amp).
If you don't plan to use the TV speakers at all then you could run the audio from the cable box directly to the amp, but you lose some flexibility that way (eg. right now you are probably using the TV to switch the audio source with the video source, a nice convenience).
Mike / technut
technut is offline
Forum Sponsor
