On the AVS forum someone told me that there's a 100 hour break in period one should abide by before calibrating. What do you guys think?
This opinion has now been confirmed. I have read it here as well as on AVS. It must be right.
But seriously, I did wait for 3 months before getting the set calibrated. If you are going to have problems with your set then problems should show up early on. So why waste money on a set that maybe shipped back. This is good enough logic for me to wait for a while. |
I think that break in period applies to CRT based RPTVs? LCDs and DLPs wouldnt need a break in period would they?
#4 | |
#5 | |
If you're talking about a professional calibration, a month or two wait is probably a good idea, also in case you have any "infant mortality" with the TV, so that you don't calibrate a TV that's going to "go back".
If you're talking about using a setup DVD, there's nothing stopping you from doing a setup right away and doing a "touch up" in a month or two.
#7 | |
I guess what I'm asking is whether I can do any "harm" to the new set if I start fiddling with the SM, so early in its "life". I've returned 5 units; I know, had I calibrated each (I didn't by the way ... only this last one), this would have been a lot of time wasted. However, is there a reason, other than this, that should keep me from calibrating one right off the shelf? I've heard that one shouldn't with CRT's. But the reasoning that applies to those units doesn't seem to with LCD's. Last edited by maxyvits; 2005-01-17 at 09:50 AM. |
I can't think of any "harm" that can be done. Perhaps JG can comment.
On CRTs I can think of "harm" from running in Torch mode for several months...
#9 |
I'd calibrate it myself right off the bat with a calibration DVD; the contrast, brightness, and colours are going to be way off. Then come back to it a few months later after if's been 'burned' in and fine tweak it.
#10 | |
#11 |
I don't believe that the LCD chips themselves will actually change/burnin, but I would bet that the rest of the circuitry does (power supply, etc). I would still follow the same steps.
#12 |
so what exactly is torch mode? My 46in. Sony (bought last year) has not been tinkered with except by me. and by tinkering I mean adjusting a few things like turning down the brightness and thngs like that.. So is that what you mean by 'torch mode'??? the fact that the TV is too bright???
#13 |
See the digital home FAQ on "What you need to do to your new HDTV". Some people call the "factory settings" Torch Mode, simply because they are usually too "hot", expecially on CRT-based TVs.
#14 |
read it a few times.. other then using a DVD to play with the settings.. As stated. by turning down the brightness and contract a little is that enough?
I dont use 'vivid' mode on the TV at all either...so I'll keep tweakin' until I think it is helping!!! Cheers Last edited by iglutikut; 2005-01-18 at 11:07 AM. |
#15 |
I find it hard to get the colours right, so the calibration CD does help. I think I got my Video Essentials from ebay for less that $20US with shipping, and only took 3 days to get here. I've done a few of my friend's Sony displays and they were all quite a bit off..
