#991 |
The amp is indeed plugged in properly. It may have been provided by Shaw, but it's several years old.
Sounds like I may end up booking a service call after all then based on what you're saying (though later on this evening I could try removing one of the splitters from the equation and seeing if I get a signal then). |
#992 |
Location: Salmon Arm, Samsung LN-T5265F, DCT-6416, B-Ray, Yamaha 6080, Energy Surround, Velodyne DPS-12B Sub.
Get rid of the amp and splitter first. The amp could be old enough that it won't pass the digital frequency's, I think it will need to be a 5-750Mhz or higher.
CMack
If you want my Cable Modem, you'll have to pry it from my cold dead hands... |
#993 |
For some odd reason my red recording light on the front my pvr will not turn off (even if it is not recording).
Oddly enough the red light is not on when the pvr is on. Although, when I turn off the pvr it stays on and will not go out. Any ideas on how to fix this matter? It started just after the new software update. |
#994 |
Turn off "RF Bypass" under Setup > Cable Box Setup.
#995 |
CMackay hit the nail on the head with this one -- 5-300MHz is what my amp is rated for.
.....the splitter itself is working fine, as one end goes to my cable modem (and Shaw Guru confirmed it was getting a good signal). The amp is not connected to the cable modem. Would Shaw provide an amp for me then, or would the quickest way be for me just to buy one that is rated accordingly? (Shaw service calls would take a few days) (EDIT: from what I see in other forums, Shaw would help out). Looks like that's the route I'll go for sure now. |
#996 | |
#997 |
I seem to have lost my skip back and skip forward functions on the remote. I tried the codes listed at the beginning of this thread (code 173) and can't get it to work. I know I have the codes somewhere but can't find them, can anyone help me (I have a 6208)?
Thanks |
#998 |
Just over a week after using my PVR, and already I've messed it up.... not good. I'm guessing I'm out of luck with this one, but maybe there's something else I can try:
I decided today to purchase an HDMI cable to replace the component cables I was using. While trying to get at a cable, I believe I pulled the coax cable from my DCT6416 (it may have been loose to begin with). The back of the receiver (where the connector is) looks normal, but now I can't get a signal at all (OOB status shows 0.00 under SNR). Is there some kind of reset I can do to the receiver, or am I SOL? (The receiver was purchased used, so I doubt i have a warranty through Shaw anyways). |
#999 |
It just dawned on me, that this was the first time trying to use the digital terminal after Shaw came out to remove the traps on the line (that were supposed to be preventing me from getting the upper-tiered analog channels). Now I'm wondering if that could have messed things up.
If this is the case, I definitely won't be happy with Shaw, since they screwed up that service call twice, and now this..... Any thoughts before i call them later today? |
#1000 |
Hi all,
I am interested in going with Shaw. I am buying a new tv and there is a deal at the store I am buying the tv at (Visions) where I can get the shaw HDPVR for $350. Is there anything I should be aware about? Does Shaw cover any warrenties for the PVR, or will I just have to deal with Visions? Should I get an extended warrenty from Visions that covers the HDPVR? Is it just better to get from Shaw directly? Say if the PVR has problems down the road...what do you think would happen? Would I have to deal with Visions, Shaw, or will they both tell me I have to deal with Motorola then? |
#1001 |
Go ahead and get the PVR from Visions -- Shaw will cover the receiver if anything goes wrong. I believe the terminal has a 3-year warranty through Shaw, so there's no point in getting the extended warranty through Visions for the receiver.
Once you get the receiver, hook it up to your TV, and just call Shaw to get it activated on your account. |
#1002 |
Location: BC. Shaw Cable, 42" Samsung DLP, 6416 w/expander & DCX3400
Also Mr. Crumb make sure you are getting the PVR model (normally sells for $498 right now) as the normal HD box (non-PVR) sells for $348. Just ensure you know what you are buying so you don't get home and wonder why you can't record.
Also the retailer (Vision) sells the product but Shaw will warranty everything and they are the ones you will call for assistance.
Designated Shaw Employee representative for Cable & Digital Cable for Digital Home Forums. |
#1003 |
Thx for the advice.
#1004 |
Is the 6412's remote a "learning" remote? The documentation provided by the links in post #1 suggest that you can "cycle" thru all of the available pre-programmed codes until you find one that works. This, however, isn't "learning".
"Learning" means that the remote can watch another remote and learn about the IR signals that it fires off. Can the 6412's remote do that? Basically, I want to purchase a generic PC USB IR remote and I want to make sure that I can use 6412's remote instead. |
#1005 | |
See Page 12 of the manual HERE. |
