Location: Victoria, BC (on Shaw TV & Internet, Telus home phone, Bell mobile)
Shaw has introduced the Motorola DCT6412. I thought we could use a thread specifically about this model, and I'm starting it off with some links and information that I have gathered recently.
The 6412 is the latest High Definition (HD) Digital Video Recorder (DVR) model in the Motorola 6xxx series of Digital Cable Terminal (DCT). Main Features: - Two tuners (vs. single tuner in 6208) - 120 GB harddrive storage (vs. 80 GB in 6208) - $748.88 (Shaw's list price, before any credits) Shaw uses i-Guide software on their DCT boxes, which does support both tuners in the 6412 (as first demonstrated by Comcast in the USA). Although there has been some discussion about the 6412 in the Cogeco forum, they are using the older Blue Guide software which does not support both of the tuners, and there are other software differences. Here are some links with 6412 related information... Shaw Info HD+PVR Digital Terminal Shaw HD+PVR User Guide (PDF, 0.5 MB) Motorola Info Product Features Multimedia Demo FAQs (6412 section) DCT6400 Series User Guide (PDF, 1.5 MB) DCT6400 Series Technical Guide / Installation Manual (PDF 1 MB) i-Guide TV Guide i-Guide (USA version of i-Guide) TV Guide 6412 DVR Manual (PDF, 2.4 MB) Prevue i-Guide (Canadian version of i-Guide) Comcast related info Comcast 6412 DVR Manual (PDF, 3.8 MB) Shaw's implementation should be quite similar to Comcast's rollout of the 6412 in the USA since both are using i-Guide software. I'm adding links to some Comcast-related information since we may learn from their experiences. (Note: Comcast is testing the Microsoft Guide in the Washington State area, so those experiences will not apply.) http://www.*************/avs-vb/show...hreadid=464986 http://www.broadband****************...flat~days=9999 http://www.tivocommunity.com/tivo-vb...hreadid=210485 Remote Control Atlas DVR/PVR by Universal Electronics (5 devices) Support Site Programming tips Other Unofficial FAQ for Motorola HD DCTs (6412 section) More to come... (Shawguy, please feel free to edit to add more reference materials, FAQs etc)
Mike / technut Last edited by downbeat; 2011-09-13 at 02:02 AM. Reason: Made thread sticky |
Location: Surrey, Shaw DCX 3400, Samsung UN46D6000, Denon Avr-1905, Paradigm CC-170, Titans, Atoms, PDR 10 v3
Great info Technut. Thank you.
I'm going to try and I stress try...., to hold off on this unit so I don't get hit with the debut price. As with the other previous terminals if you wait a bit you get a better price. Only trouble is the waiting! hahah. Last edited by Sith; 2005-01-02 at 04:21 PM. |
Prices for the Motorola DCT6412 from Canadian cable providers:
Access : $750 to buy, $16/month to rent Cogeco : $800 to buy, $20/month to rent Shaw : $750 to buy, no rental option Note: Cogeco and Access currently have only one of the two tuners enabled. And for comparison purposes, here are recent DCT6208 prices: Aurora : no option to buy, $20/month to rent Cogeco : $699 to buy, $20/month to rent EastLink : no option to buy, $15/month to rent Mountain : $700 to buy, no rental option Rogers : $700 to buy, $20/month to rent Shaw : $500 to buy, no rental option
Mike / technut Last edited by technut; 2005-01-26 at 04:45 AM. |
I also would like to say great info technut thanks I,m from Regina and subscribe to Access cable and I'am looking forward to getting the Iguide here instead of using the blue like we are now. So this is a chance to see what we are going to be getting. I,ve also been watching the comcast iguide forum on avs and learning alot about it there, the ups and downs as such. The 6412 that I have also runs very quietly can bearly even hear it.
#5 | |||||
From the TV Guide 6412 DVR Manual (PDF, 2.4 MB), some of the advantages of two tuners:
Mike / technut Last edited by technut; 2005-01-03 at 03:00 AM. |
#6 | |
From the TV Guide 6412 DVR Manual (PDF, 2.4 MB), an i-Guide feature for recording a Series of shows:
Mike / technut Last edited by technut; 2005-01-03 at 03:45 AM. |
DCT6412 Remote Control
There are now two virtually identical remote controls that Shaw issues with the 6412, but there are minor differences when programming the remote. The newer remote (ver.2) has a pre-programmed SKIP button just below the MUTE button, and a MUSIC button just below the LAST button. On the older remote (ver.1) those buttons are labelled HELP and LOCK. Add a SKIP button: The 6412 has a 30-second commercial SKIP function (same as the 6208), but there is no corresponding control button on the (ver.1) remote to activate it. You can add a SKIP button to your (ver.1) Remote by following these steps: 1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode. 2) Press and hold the "Setup" button until the "Cable" button blinks twice. 3) Type in the code 994. The "Cable" button will blink twice. 4) Press (do not hold) the "Setup" button. 5) Type in the code 173. 6) Press whatever button you want to map the SKIP function to. Muted after a recording: When the 6412 powers up automatically to start a scheduled recording, it mutes the audio out (possibly to prevent it from blasting you in the middle of the night if you accidentally leave your audio amp powered up). This mute is on the 6412 itself and there is no corresponding control button on the remote to unmute it. You can add the necessary Mute button by programming the remote with a code 141 (code 00141 for ver.2 remotes) using the same procedure as for the SKIP button, above. Or to issue the signal only once (without mapping it to a button), follow these steps: 1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode. 2) Press the "Setup" button and 141. (00141 for ver.2 remotes) Or just don't turn the 6412 off... the recording will still start but the audio will not be muted. Restoring a button to the original function: To undo a change and remap a button back to its original function, follow these steps: 1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode. 2) Press and hold the "Setup" button until the "Cable" button blinks twice. 3) Type in the code 994. The "Cable" button will blink twice. 4) Press whatever button you want to restore, then press it again (ie. press twice).
Mike / technut Last edited by technut; 2005-05-06 at 03:22 AM. |
I don't know if the 6412 uses different i-guide software, but the 6208 definitely does not have a 'Create a Series Recording Icon'. If fact, this has been one of the main deficiencies of this unit compared to Tivo, which handles Series recording beautifully. If this is actually something that the 6412 has, I will definitely be looking into dumping my 6208 in favour of the 6412!
#9 |
Yeah the series recording would be awesome. Unfortunately it would no doubt work off the box's guide information which is usually wrong anyways!
#10 |
Now, How would I get a custom programmed skip feature into my Harmony remote that takes their programming information off of the DCT's features...
(I think I know the answer but maybe someone else has already applied this to their universal remote)
One thing for certain... none of us are getting out of here alive... |
#11 | |
Do you want to add the DCT Skip button mentioned above to your Harmony remote? Do you have the H659 or something else? |
#12 |
Its a 628 - great unit in the insane world of universal HT remotes - and I obtain all programming codes off the web (instead of head to head programming)... I suppose that would mean I need assign off the original remote, then cross function off the new remote.
#13 |
Some tips and quotes from users of the 6412 on other cable systems:
Noise Levels: "Just wanted to report back that this box is dead quiet compared to the 6208. Doesn't seem to be a fan in it unless they put in ultra quiet ones." Playback controls: "When viewing a program the > is forward, ^ is play/pause, < is reverse, and the bottom button is 'live'. I find these buttons much more convenient than the identified transport controls" (with updates from the TV Guide manual & Felgar) No RF output: Unlike the 6208, the 6412 does not have an RF (coaxial cable) output. If you have a requirement for this you'll have to add an RF modulator to your setup.
Mike / technut Last edited by technut; 2005-05-06 at 02:37 AM. |
#14 |
Thank you in advance. I run a 46" Samsung DLP through DVI for reference.
1) I have a non HD SHAW box that uses the new menu system and love how fast the menu scrolls through the channels. There is virtually no delay at all if channeling up from 5 to 6 or from 11 - 12- 13. The 6208 had about a 3 second delay between channels. I returned the 6208 because of this. Has SHAW fixed that issue with the new 6412? 2) The 6208 would change the analog signal to a digital signal in the box. Please tell me that Motorola and SHAW have set this new box up so that it leaves the analog signal alone. Standard Definition through S-Video on my DLP is GOOD. Standard Definition through the HD box via DVI is brutal. 3) Since the signal from Star Choice is digital from the source, Standard Definition would remain really good through their HD box via DVI. I'm not sure if I should keep waitng for the Star Choice HD PVR or go back to SHAW with this new and hopefully improved 6412..... anyone? |
#15 |
I haven't owned either, but my guess is that 1) and 2) are both due to the box recording everything, so it has to digitize everything. This may be the cause for the channel change delay, and is almost certainly the cause of the lousy analogue SD. I'd guess the 6412 works exactly the same way.
