SA8000 Series scrolling interference - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2005
Old 2005-01-01, 07:21 PM   #1
pkrash
Default SA8000 Series scrolling interference
I am seeing a scrolling (rising) greenish tinted band, half the screen height, on off-air screens and some lower channel programs that seems to be coming from the SA8300HD. It is less evident with the 8300 than the 8000.
It's Rogers with a Panny 42PHD7UY and Monster AV700 power bar.
Different than the vertical bars of the other posts.
I have no other splices in the cable line.
It is not present with the DVD player.
It is not the switching receiver.
I am checking for alternate power/ground loop.
Can Rogers install a filter?
Any suggestions?
pkrash is offline
Old 2005-01-02, 07:25 PM   #2
pkrash
OK, I think I beat it.
Ran the cable feed through the AV700 power bar.
Go figure. It's clean now.
I never bothered using it before because I thought it may
cause more signal degradation.
pkrash is offline
