Recording a show fails every time, really strange. - Canadian TV, Computing and Home Theatre Forums
Old 2013-10-07, 12:32 AM   #1
M.Richards
Default Recording a show fails every time, really strange.
I have a Record a Series set up for the 1:00pm Eastern showing of The Price is Right, on channel 528 in Ottawa (CBS West).
For some reason, every single day the recording is corrupted. Last Friday's show is in my recorded list as only 8 minutes starting at 1:52pm. Thursday is 21 minutes. And on and on it goes, it's been a couple of weeks since I got a good recording. If I attempt to play one of these, nothing happens.
There are no other recordings scheduled at this time, so nothing is interfering. In fact, I've had to start recording the eastern broadcast on a different channel and time, one which conflicts with another recording, but recording two things at once works ok, better than the one alone.
I've got an 8642, but I really think the hardware is irrelevant here. I can record everything else I want.
Anybody else see something like this? I'd love if someone in Ottawa or similar could try and record it as well and see if it works.
M.Richards is offline   Quick reply to this message
Old 2013-10-07, 01:14 AM   #2
Location: Toronto, Rogers, 9865 & 8300-eHDD, Panasonic TCP65S1, Denon AVR4310Ci; Sony KDL40W3000, 8300-eHDD
Have you performed a reboot?
Have you tried deleting the scheduled recording and redoing it?
Have you tried setting a single recording?
Have you checked your signal strength and S/N ratio on that channel?
What happens when you tune to channel 528 to watch?
Do you record any other programming on that channel?
Have you tried pressing the record button when watching 528 to see if the PVR records then?
http://www.digitalhome.ca/forum/showthread.php?t=17719
57's Optimization Services (Home Theatre Optimization) . . . . 57's Home Theatre (Latest equipment & photos)
57 is offline   Quick reply to this message
Old 2013-10-07, 05:29 PM   #3
ExDilbert
I had a series that recorded only 1 minute of each show. Unplugging the PVR for 30 seconds fixed it.
ExDilbert is online now   Quick reply to this message
Old 2013-10-09, 01:44 AM   #4
M.Richards
Yes, I've rebooted. Signal strength is fine, levels are 0, S/N 36dB. The PVR has no problem recording the show immediately before and after on the exact same channel, and it's not like the signal would suddenly drop every day at 2pm.
Can only try one trick a day, and have set up a new recording. I'm 100% confident it won't change anything as there's nothing wrong with the scheduling. It starts up the recording every day on time, and screws up during the show.
I'm positive it's not my equipment. There's something screwy about this *one* particular broadcast.
Old 2013-10-09, 03:39 AM   #5
JoeSoap
Simsub? We've seen issues with the starting/stopping of simsubs.
Let me check..., yes there is a potential simsub. ctyv, 583 in Waterloo.
Simsub or not, the solution is to switch to the Canadian "broadcast" at the same time.
JoeSoap is offline   Quick reply to this message
Old 2013-10-09, 10:15 AM   #6
Thanks JoeSoap. That's one item I forgot to mention. Always, always record the Canadian channel (if the programme airs on one) to avoid simsub issues.
Old 2013-10-11, 03:12 AM   #7
M.Richards
I guess that's it, as I recorded 583 successfully.
One of the primary reasons for recording the US broadcast was to get the US broadcast though, as I hate what the Canadian channels often do to the broadcast.
I guess there wasn't a simsub on 583 last year.
Thanks.
Old 2013-10-15, 01:22 AM   #8
leeanne172
I had the same problem with that same channel but for Judge Judy recordings at 7pm and 7:30pm, sometimes it would record some of it and other times it would just freeze part way through the show while watching back .. the channel has nothing wrong with it as far as pixelation or blipping. I went back to recording the show on Fox at 6:30 and 7PM and have had no issues since.
leeanne172 is offline   Quick reply to this message
Old 2013-10-16, 07:01 PM   #9
wysiwyg
I always thought they can only do the simsub when there's a local OTA station offering the same broadcast. If I want to record Letterman on CBS-W and there's a station in Vancouver showing it as well, the CBS feed was always available. Even if it is simsubbed, shouldn't it show the Vancouver feed instead, as if I tuned the CBS station live?
wysiwyg is offline   Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
