How to properly align your satellite dish - Discussion and Tips - Page 23 - Canadian TV, Computing and Home Theatre Forums
Old 2009-10-10, 08:11 PM   #331
autoblitz
Default help please
i have echo star 110 west up on screen trying to find bellxpress sat dish at 91 w but when i turn the dish that direction i get unkown sat on screen any ideas
autoblitz is offline   Quick reply to this message
Old 2009-10-10, 09:40 PM   #332
lightningflik
do you have an old receiver? or a brand new one? if you do and the softare hasn't been updated then yes, this makes sense. Try running a checkswitch, if it confirms a signal to SAT 91, then all you need is the software download. The Bell satellites were changed last spring and new software is needed to name it in the point dish screen.
lightningflik is offline   Quick reply to this message
Old 2009-10-11, 08:50 AM   #333
Pinza
If you are still not certain you have the correct bird, I would ask a friend or neighbor with Bell if you can just connect your receiver to their Dish to download the software. A Bell world should be able to help too.
Pinza is offline   Quick reply to this message
Old 2009-10-15, 02:26 PM   #334
thepolishprince
Default Can't find 82??
Hey gang here's my situation...just picked up a new 6131 HD receiver. Picked up a new lnb and a SW21 switch. Installed everything, check switch, can get 91 just fine 90%, but it won't find 82. What's up? Do I have to register it first in order to get 82? Can't figure it out for the life of me.
thepolishprince is offline   Quick reply to this message
Old 2009-10-15, 02:59 PM   #335
Pinza
Was the Dish already Skewed.?
Have you set the Skew.?
You do not need to do anything other than a 'check switch" to see 82.
Disconect the 82 LNBF and SW21.
Peak signal after skewing the Dish on 91.
Connect SW21.
Run 'check switch'.
Old 2009-10-15, 05:14 PM   #336
thepolishprince
yeah...I'm getting 91 just fine...my receiver knows there's a switch there, but it doesn't see 82....that's why I'm wondering if you have to register it first...I haven't registered it yet.
Old 2009-10-15, 05:16 PM   #337
Pinza
Are you getting 91 on the correct LNBF.?
That is why all aiming should be done with no switch's.
Old 2009-10-15, 05:53 PM   #338
thepolishprince
Yeah I get 91 no probs without the switch
Old 2009-10-15, 06:14 PM   #339
Pinza
Old 2009-10-16, 08:51 AM   #340
thepolishprince
OK...tried again last night for 4 hours....started from scratch...one lnb, left side (from back of dish) directly connected to receiver...no switch. NOW....all I can find is 82 @ 98% and I even found Echostar 110 @ 97%...tried for 2 hours to find 91 but couldn't. This has never..ever happened to me before..I'm lost for words...what the &^%$?...Am I missing something?
Old 2009-10-16, 09:34 AM   #341
Rex The King
Smile
You still have not answered the question about setting the correct skew for your location. Remember when setting up your bell dish with two lnb's you have to set the skew. BTW this is a compromise between the sats when it comes to quality of signal as opposed to a single dish aimed at one sat. Aiming for 91 sat and having your skew set properly you shold pull in 82 with no problem.
Rex The King is offline   Quick reply to this message
Old 2009-10-16, 09:57 AM   #342
thepolishprince
Wouldn't my skew stay the same, as I already was able to pull in 91. Now it has completely reversed without any modifications. I get 82 on the 91 side and can't find 91 even by moving it. I still should be able to get some sort of signal from 91 without adjusting the skew right?
Old 2009-10-16, 10:11 AM   #343
Pinza
Your skew will ONLY stay the same if the Dish was skewed correctly in the first place. Although Bell installers are required to skew all Dish's, even if just 91 is required, not all do this. Hence the questions.
Old 2009-10-16, 11:11 AM   #344
thepolishprince
Sooooo...if I'm getting 82 at 98% and can get 110 @ 98% (with 1 lnb)...and could get 91 yesterday (but can't now)...I shouldn't have to adjust the skew right? I've always had no problems finding it before..this is why it baffles the **** out of me.
Old 2009-10-16, 01:11 PM   #345
Pinza
Do you actually know what the skew is and does.?
I am sorry but this is the third attempt at asking a simple question, why is it so hard to answer.?
Lets try something more basic;
What is your location.?
What is the Skew setting on the Dish.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
