Bell Aliant Fibreop email - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Aliant Home Phone, Internet, IPTV
Old 2012-09-20, 01:15 PM   #1
HFXRock
Default Bell Aliant Fibreop email
I am looking for the IMAP/TLS settings for NS Bell Aliant Fibreop so I can get email on my Android device.
Does anyone know these?
HFXRock is offline   Quick reply to this message
Old 2012-09-20, 01:38 PM   #2
file
You may be able to try imap.bellaliant.net as the server address, and the same username/password you use for webmail.
Disclaimer: I don't use bellaliant.net email and don't even remember my username/password.
file is online now   Quick reply to this message
Old 2012-09-21, 05:54 AM   #3
Tridus
http://nsegainkc1.aliant.net/knowled...ngs/index.html
Tridus is offline   Quick reply to this message
Old 2012-09-21, 11:53 AM   #4
HFXRock
they have imap.bellaliant.net but it doesn't work with outgoing lol, I had to use Gmail's outgoing server and it works just fine.
Old 2012-09-21, 05:21 PM   #5
FuzzFace
does smtp.bellaliant.net work for outgoing?
FuzzFace is offline   Quick reply to this message
Old 2012-09-25, 12:55 PM   #6
HFXRock
Nope none of it works.
This is from the Eastlink site:
If you are using an Eastlink-provided email addresses, but currently connecting with a mobile device to a different Internet service provider, you will need to configure the mail server settings of your mobile device using StartTLS or SSL encryption.
So this is what bell Aliant needs. And because the email resides with Aliant and the TLS allows mobile phones to get email regardless of internet provider and that the two don't work together means, it will never get done!
Old 2012-09-25, 02:52 PM   #7
FuzzFace
found this on bellaliant.net
Outside Bell Aliant Network (on another Internet connection including Bell Mobility's 3G/4G Network)
Incoming Mail Server :
pop.bellaliant.net
Outgoing Mail Server - Bell Mobility:
mail.1xbell.ca
Old 2012-09-26, 02:00 PM   #8
HFXRock
That server works fine on my wifes HTC but it doesn't work on my S3. I can receive but cannot send. Its with Level 2 now. But that server also requires turning off wifi, which I want to avoid doing, so Bell Aliant needs to add TLS support to their exchange server, its easy to do but getting someone to do it is not.
Old 2012-09-26, 05:23 PM   #9
file
Those servers aren't Exchange. I believe it's an old email platform that may not even have support for TLS or SSL.
Old 2012-09-27, 07:14 AM   #10
HFXRock
I couldn't get an answer from calling support, but I did get support on the Facebook page surprisingly enough and this is their response sounds like SSL TLS in the new year maybe:
HI Jeff
Thank you for your message.
Please follow up with us if the new set top box does not address your freezing issues.
With regards to your email access, unfortunately I don't have a quick fix for you. We appreciate your patience and understand the inconvenience that this may be causing. We are aware of the issue and have it in our plans to be addressed in the first quarter of 2013.
Thank you for your feedback. I have forwarded your email as well to our development team.
Old 2012-09-27, 05:37 PM   #11
sgu222e
I setup my Aliant email on my Nexus 7, using the standard Pop3 and SMTP servers for NB and it is working fine, though I had to use an alternate port for SMTP.
Not sure if similar settings would work for NS or not.
Incoming
Username: My Aliant email address
Password: My Aliant email password
POP3 Server: pop.nbnet.nb.ca
Security Type: None
Port: 100
Outgoing
SMTP server: smtp.nbnet.nb.ca
Security Type: None
Port: 587
Require Sign-in is not checked.
sgu222e is offline   Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
