1. HSUD (Hard (disk drive) Spinning Up and Down) This HSUD causes issues on playback with pauses/freezing (glitches) when the drive spins down. One workaround is to constantly record say an SD channel (Galaxie would use little HDD space and may be easier on the HDD). (of course this may cause recording conflicts, so beware). The glitches can also be present when just watching a channel since the HDD is always buffering the channel you're watching.
2. Recorded List now goes to the beginning rather than "staying" at a selection after erasing a programme or whenever going to the list. (alphabetical or by date) This makes it difficult to monitor recordings (which used to come up on the first screen), or to watch the "next recording" like you used to.
It also goes to the beginning of the list if you check the amount of HDD space used (B - Preferences) button and then C to return.
Summary, when you press list, you are taken to the beginning of the list, regardless of what functionality you used to have - such as going to the next recording, going to a current recording, pressing preferences to see HDD space, etc. It's possible this is an attempt at "consistency" by Rogers since you used to be taken to various places depending on what was happening. Now you're always at the start of the list, regardless.
3. When trying to record programming in the future, the default position for "select" is to "change to this channel" rather than "Record". Workaround is to press record button instead of select, or scroll down to record selection. Those used to pressing the select button twice when setting future recordings will find this most frustrating since you'll be bumped from where you were in the IPG and you'll have to find your place again.
When the IPG is at the current time, it will switch to the channel regardless, so you'll need to press the record button instead - the select screen won't even come up.
4. There is missing information in the IPG - a few days out. If that is missing when you set the recording, then there may not be any "info" when you look at the recording in the recorded list. Missing information seems almost random since info can be there for say Sunday, but missing for Saturday.
5. If the HDD is spun down, the PVR may take longer to come to life when you turn it on, or to respond to a button press to say "play" a recording.
Please report to Rogers and if they say the issue is unknown, quote some of the reference case numbers from this thread. There is now a Master Ticket PT00063763, so you can quote that. Please advise Rogers that there are more issues than HSUD as outlined above (IPG, Glitches, etc). The ticket may only reference HSUD.
Here's the (short) list of positives:
A: Previously, after a reboot the warning message about the external drive would remain on-screen until I hit the Exit button to dismiss it. Now, after a reboot the warning message appears briefly then disappears on its own. (Some people have reported seeing the eHDD message each time they turn the PVR on - obviously not a positive, just a mention)
B: Previously, when you tried to schedule a second daily recording (same channel, same programme), the first recording would vanish. You can now schedule two daily recordings.
C: The HDD info in the diagnostics, which vanished a couple of firmware versions ago, has returned with 14.1 and 15.1.
I have the same problem. Update was at 3:00AM on Thursday morning. When the internal drive spins up or down, playback of recorded shows halts for 2 seconds. I have an ESATA drive , so I assume I am playing back from that. I have found that the HSUD and the playback pause does not occur while recording another show.
Two other issues with this release:
LIST now always starts at the beginning of the list, not where you were previously positioned.
In the guide, when you are trying to schedule a recording, it always defaults to "switch to this channel" rather than "record".
I reported the problem to Rogers support on Friday. Got a voicemail from Rogers in the afternoon saying my problem was resolved. No change after a reboot.
After running reltively smoothly for many years, I had to reboot three times in the last week when pausing live TV stop working. A reboot fixed that. Not sure if it is related to the new firmware///
I've noticed over the last couple of days that my PVR has been stuttering playing back recordings. I've never experiences this before. And I've heard the hard-drive starting to sping related to this.
I've had this unit since at least 2008, though I didn't add the stand-alone extra drive until after this issue seemed to be resolved last time.
Well, at least it's not my machine about to fail then ... i
One thing that seems to be fixed is the "Ghost Recording" issue which I used to see at least once a week. With this GR problem the PVR would think it was recording something but wasn't, so if you were recording 1 program and also had a GR going on then you could watch live TV but could not REW/Pause/FF. Also if you have a GR you could only record one show. Once or twice when I hadn't realized I had a GR I must of had a second one as well because then there would be nothing recording but I could still not Rew/Pause/FF live TV. The workaroud for that was to unplug/plug in power causing a Reboot.
I haven't had any GR issues since early Sept when I got this version of SARA.
With an external drive, I'm noticing that every time I turn my PVR on, the message warning me I have an external drive pops up; previously it only popped up after a reboot.
So does this reflect a change in SARA, or is it another module we should be looking for?
From a layman's perspective, it does appear that they are attempting to deal with the loss of data on external drives - but may have created other problems. Are people without external drives seeing this spin/stutter issue?
Edit - oh wait, this is a new SARA then ... I missed the 1.93.14.1 post ... and the thread split. I wonder how long we have to deal with this malversion.
I just watched a couple of hours of cartoons with my daughter this morning, and I haven't noticed any stuttering either. Though I was seeing it through a couple of reboots previously.
One change of behaviour I'm noticing is that it used to be when you had a list of recorded programs, and you played something, when you returned to the list, it was still at the one your are playing; now it seems to default back to the top of the list. A bit frustrating when you have a long list of the same program, and your trying to figure out which one is which.
Playback "stalls" or stutters, and a default has changed
Hello all:
I could use some help here.
SA8300HD PVR, Rogers service
Vantec NexStar3 NST-360SU-BK external hard drive enclosure
containing Western Digital Caviar SE16 (WD6400AAKS) 640GB HD.
This combination has been working well for four years.
Diagnostics screen, "Software Versions" section shows PVR has FLASH: DVR1.9.0_8300_MR.HR_F.p.3004.
Diagnostics screen, "Component Information" shows SARA: 1.93.14.1.
There's also a section showing "Software Anomolies" with entries for today's date.
ISSUES
When watching either pre-recorded programs or live TV, the show will "stall" or pause for a couple of seconds, then continue. If I rewind and replay that section, it plays fine. That may suggest that the issue is in playback, not in recording.
I have done a few reboots.
I wonder seems if there was a firmware update or some change recently, as using the Guide to record shows now works slightly differently. Previously I would navigate to a future program block in the Guide, press the Select button (which opens the Future Program Options screen) and press the Select button again to Record (as the Record option was default highlighted). Now, after entering the Future Program Options screen, the "Tune Ch. xxx immediately" option is default highlighted, so I must manually select the Record option and then press the Select button. This has changed sometime in the last 10 days.
QUESTIONS
Was there some sort of update in the last 10 days or so, that caused the change of default option in the Future Program Options screen?
Does the recurring "stall" or stutter indicate that something is failing?
If so, what's the best way to isolate the external HD to narrow down whether the issue is with the external HD or with the PVR itself?
Be sure to do a reboot or two. This may (or may not) eliminate some of these issues. Your post was moved to this existing thread, please read earlier posts.
Sorry. I had written up my post while being unable to find anything in the diagnostics screens resembling firmware version numbers. Just at the end I found SARA version and posted. Now that I have that SARA version, I saw that there's a thread with that version with similar problems. Had I been able to find that SARA version earlier, I would have known to post in that existing thread.
If enough people complain, yes, they have been known to issue corrections, as with previous firmware. Sometimes this takes longer than other times - depends on the issue and how easy it is to fix. Often there is not a new firmware version, but rather a new download with an incremental change to correct the issue.
is there a reliable e-mail address for submitting such issues to Rogers? As there are multiple issues with this update, perhaps it might be better to submit in writing. Or, is it better to phone them?
My SA8300HD rebooted by itself at 9:00PM on Monday. I was hoping it meant a fix had been found, but there is no change. HSUD every 2-3 minutes unless something is being recorded at the same time, and the LIST change and the Guide record change are still there.
- List browsing now resets itself back to the first program in the list when erasing a recording.
- Hard drive randomly spinning up when the unit is off.
- Stuttering playback sometimes.
Very upsetting. My only consolation is that I thought my hard drive was going - but now that I know others are having the same issue, I know its not that
I've been having these same problems for the last 4-5 days. During playback it will stop, the image and sound will just freeze, and then there's a click sound and a spinning up sound, and then it resumes playing. It's random, every 5-10 minutes and occurs when playing off the internal or my external HDD. If I rewind it will play back the same scene fine. Also, half the time I turn on the PVR it gives me the "external HDD can be used" message as if I had just connected it or rebooted. I thought that one of the two HDDs was failing but after reading these posts I realize it may not be my hardware. It's been running fine for probably 3+ years until now. Couldn't be happening at a worse time, the new TV season is about to start!
I read some more posts and realized that I also have the issue where erasing a recording makes the list flip back to the first program. Really annoying.
As is unfortunately common on Internet forums, the various people posting their issues in this thread seemingly did not bother to inform Rogers. How do you think these issues will be fixed if you don't inform Rogers?
I spoke to Rogers Customer Service and Tech Support, and they said that no one had reported the issues of the stuttering/stalling, nor the List issue. One person had reported the new default of the Record options.
I have given them full details of all three issues, and they've opened a ticket with Enginerring.
Please, if you want to accomplishi something instead of just posting your issues in this thread, phone Rogers to report the issues.
I realize we need to inform them, I just dread calling up and having them try to walk me through fixes that won't do anything or schedule a service visit or something. I'll let them know, any tips on how I should approach the call? I just want to file the complaint and have them look into it on their end and then get off the phone.
Ditto ... I cringe at the thought of calling them, and trying to avoid the usual solution of them sending a technician to solve the problem ... It's Rogers, what the F is the point ... they'll fix it when they are good and ready ... they just lie outright when you say that you hear other people are having the same problem.
I don't need that kind of hell in my life ... or the resulting PTSD.
Normally, I'd e-mail something in ... but if they can't be bothered to reply to e-mail anymore then why bother ...
I didn't have to do any of that. My phone conversations (first with Customer Service, then transferred to Tech) were pleasant. They took the details, took the issues seriously, and escalated to Engineering.
Let them know that many people are experiencing identical issues with this latest firmware update. Inform them that my ticket has already been opened on this.
Is it for sure that they did a firmware update this week? Can I refer to that like it's a fact when I talk to them?
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
1.7M posts
114.9K members
Since 2001
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
