630 Is Hot, Hot, Hot - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2012-07-18, 03:52 PM   #16
TheHans
Originally Posted by noah12 View Post
About 74 degrees F, 22 degrees Celsius, just above room temperature. I just touched the entire bottom, held my hand on it, warm not hot. Only have the air conditioning on when needed, in a cabinet with plenty of ventilation, with laptop cooler blowing on it from the side.
Noah12, just to clarify if you don't mind, when you say your 630 is 22 Celsius, is that based on going in via the hidden menus to read the temperature? Or is that more of an ambient reading?
TheHans is offline
Old 2012-07-19, 12:49 AM   #17
noah12
DHC Supporter
ambient dont know how to read the temp via hidden menu
noah12 is offline
Old 2012-07-19, 02:25 AM   #18
GaryE
Options-4-9-7-7-1 (9-7-7 will be hidden), then press the left arrow button once. The temperature of the drive is under the word "Internal".
~Gary
Shaw Direct 630 HD/PVR | WD My Book AV eHDD | Sharp Aquos 46" 120Hz LCD TV | Watch me LIVE!
GaryE is online now
Old 2012-07-19, 08:20 AM   #19
ScaryBob
The drive is not the issue. 2.5" drives produce very little heat and the 630's drive is just above the fan (which runs all the time.) The main heat producer in the 630 is the main chip in the center of the unit, toward the rear. (That's where the warm spot on the bottom is.) There are vent holes just above it but no active cooling. That makes airflow above the 630 important in order to keep it cool.
ScaryBob is offline
Old 2012-07-19, 02:44 PM   #20
noah12
DHC Supporter
Got it 37 under internal
noah12 is offline
Old 2012-07-19, 06:43 PM   #21
TheHans
That temperature's quite low relatively speaking. It's good to have a yardstick. Thanks for posting that Noah.
TheHans is offline
Old 2012-07-20, 06:44 AM   #22
QCK
If your receiver is anywhere close to being hot to the touch it is not normal and needs to be replaced. Something is very wrong with it and more importantly this can be a fire issue as well. I have 6 of the 630s and all of them are at a normal running temperature you would expect from any modern equipment.
QCK is offline
