Receiver loses memory after power failure? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2012-06-24, 04:59 PM   #1
danomac
Default Receiver loses memory after power failure?
Hi all,
I recently sold my old receiver to someone who was very unhappy with the sound of his new TV. His son gave him some proper bookshelf speakers and we found rear speakers and a center channel on craigslist. Off the top of my head this is a Pioneer V704S.
He's very happy with the sound now, he says he can annoy the neighbours now if he wants.
However, the last two power failures the receiver lost its memory. Normally this isn't a very big deal, but this unit was one of the early models that allowed you to map optical and coax to any input you choose, and therein lies the problem. It resets and the poor guy is lost with no sound for his TV and BD player. He's not very technically inclined and is completely lost when this happens.
Now, the memory on that unit had been working fine. In fact, it still remembered my old settings that I used in my living room from 2 years prior. (It had been sitting for a while.) This amp is working perfectly in every other way.
Can anyone think of why it would stop remembering settings all of a sudden? Power failures where he lives (rural) are common in winter. Is there a battery in it even? I guess that could explain it if there was...
danomac is offline
Old 2012-06-24, 05:48 PM   #2
There may not be a battery, but the ROM could be somehow compromized, or perhaps there is a capacitor that is not working properly any more - I've encountered this on several clock radios that forgot everything. He could plug it into a UPS and make sure he shuts the AVR off as soon as there is a power failure so that the UPS can sustain the memory during the power failure.
57 is offline
Old 2012-06-24, 06:34 PM   #3
danomac
I thought about the battery backup/UPS. The problem is he can go 24h+ with no power. Once it was almost three days before his power came back.
It could be a stopgap measure for now. And I'd have to make sure he understands that he needs to have the amp in standby if the power goes out while he's watching TV.
danomac is offline
Old 2012-06-24, 07:50 PM   #4
Jake
Not a solution but a workaround. I would find out what the audio is defaulting to during a reset and set everything up that way. So if coax1 is defaulting to DVD and optical1 is defaulting to AUX then hook up the devices to those inputs. I assume the video is assignable too. In which case make sure you pair the correct audio with the video.
Jake is offline
