Can anyone help me with the sat code for a bell dvr. Also how do yo program it in?
Thanks in advance |
Yes I got it to work but I still need the the code. A wr7 is a universal remote.
Anyone know the code for the bell dvr?
122. It's at the back of the manual Pinza just posted.
http://www.retrevo.com/pdf/23581dj19...sal+Remote+WR7 |
Thanks but code 122 does not work with the bell pvr. Any suggestions?
FYI - I have emailed WR7 three times and they have not replied. |
It should if the Remote Code on the PVR is the default one.
Sorry could you explain.
#9 |
If you have changed the Remote address on the PVR the WR7 might not work it, same thing happens with other so called Universal remotes.
They need the Bell TV PVR to be set on Remote Address 1, which is the default out of the box setting. |
#10 |
Just use the code 122, go to the System Info screen and press record on the remote. If that doesn't work, you're probably out of luck.
