hello everyone I am somewhat of a newbie when it comes to AV Receivers.
I currently have a Pioneer Vsx d814 Receiver, I am currently running 7.1. I have two tower speakers with one 12 inch,4 inch,and 1 inch tweeter. Center channel is two 6.5 inch with .75inch tweeter and four surround speakers 6.5 inch woofer and 1 inch tweeter. The Receiver I have does not have any HDMI inputs, I am currently considering two different models and needs some help. 1.Pioneer VSX 921k and Pioneer VSX 1126k. The 1126k is a future shop exclusive model http://www.**************/en-CA/prod.../10175728.aspx I know both models are totaly different but i would like to know sound wise if there would be much differences.Dont care about the extra features just care about sound quality.Can some please help me....Thanks..... |
The quality of sound depends on many factors but typically the biggest factor in determining the quality of sound is your speakers.
With mediocre speakers, you'll get mediocre sound regardless of whether you hook up a $200 receiver or a $2,000 receiver. Difference between a $400 and $800 A/V Receiver is typically features (more inputs etc) and amplification (more wattage). More wattage does not mean better sound, just the ability to amplify the sound in larger rooms.
You indicated that sound quality is a priority. Do some research on the benefits/features of MCACC and Audyssey MultiEQ XT in performing equalization of your speakers and sub.
Here's an FAQ to ensure the AVR has the features you need, but it sounds like both AVRs have most of these...
http://www.digitalhome.ca/forum/showthread.php?t=76082
thanks you guys for all your help, but i have one more question...for both of the receiver i am considering here are the specs can someone help me understand what they mean.....
pioneer vsx 921 k Amplifier Section Continous average power output of 80 watts per channel,min,at 8ohms,from 20 hz to 20 000 hz with no more than 0.008% total harmonic distortion. Front (stereo) 80W+80W Power consumption 500W Pioneer vsx 1126 k Continous average power output of 110 watts per channel,min,at 8ohms,from 20 hz to 20 000 hz with no more than 0.008% total harmonic distortion. continous power output (20 hz to 20 khz, 8ohms,0.08%) Front 110w+110W Center 110w Surround 110W+110W Surround Back (front height/wide) 110w+110W Power Consumption 570W The 921 does not list all the channel, so does that mean that it would not output the stated watts per channel and the power consumption for both receivers are close, does the power consumption have anything to do with output power? |
Here's a previous discussion regarding "Watts", which is a spec that most people should ignore...
http://www.digitalhome.ca/forum/show...ighlight=Watts Post 2 Power consumption numbers should be ignored since they have no value. The AVR will use very few Watts when listening to most programming.
hey guys sorry for all the newbie question, but this is my last one. If you guys had to choose one receiver, Pioneer VSX 921 k or Pioneer VSX 1126 k which one would you guys choose? considering that the main thing is sound quality...both receivers has more hdmi input than i need, i have an apple tv so streaming is not an issue...Thanks For Your Help....
Isn't that what you asked post #1.
#9 |
Thank You All For Your Help
#10 |
I am a rookie when it comes to home theatre setup. I have installed and wired in 5.1 surround in my basement, with all of the speakers wires fed to a media closet. I have also wired in 2 speakers upstairs in my sitting room (for a tv) along with several other speakers upstairs with volume switches. I have HDMI connections all running from the TV's to the media closet (which is also where my shaw gateway hubs will be connected).
What I want is to be able to buy one receiver that will play 5.1 surround sound in the basement at the same time as playing the sound for my tv upstairs (without breaking the bank). I was told the Onkyo TX-NR609 would do this, but when I look now I see that the Pioneer VSX 1122 might be a good fit. Advice? |
