Star Choice 48" Dish - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2012-06-04, 05:22 PM   #16
AFF
Tons of those up here in the Arctic. I use one for 91 (Bell). I bet if I went out to the local landfill I could pick 5 or 6 up with lnb's for DirecTv or Bell on them.
AFF is offline
Old 2012-06-04, 05:35 PM   #17
cyberham
After reinstalling the original LNB and doing further testing today, I have confirmed the LNB is circular with LO of 11250 MHz. I received the Nimiq (Bell) and Dish satellite scrambled signals with 76% quality. It works well.
I've now removed it again and reinstalled my linear LNB. I used black tape to build up my LNB diameter so it fits the original holder tightly. I now need to re-orient the dish since this has relocated the LNB to the new (correct) position.
The measured dimensions of the dish surface is 40 inches wide x 44 inches high. So the 48-inch advertised measurement was incorrect. But it is a nice and strong dish using heavier gauge metal than the one I had before. I needed help hefting it into place whereas I installed my lighter dish before alone.
cyberham is offline
Old 2012-06-04, 08:05 PM   #18
dirtroad
Sorry I miss identified the lnb, that is the exactly why I don't eat anything in the fridge that isn't labelled, even if I think I recognize it!!
If Life is a Highway,...then why is there no end to this dirtroad?
dirtroad is offline
Old 2012-06-04, 10:23 PM   #19
cyberham
I generally eat what's in the fridge...as long as it's not moving.
cyberham is offline
FTA Forum Sponsor
