#16 |
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
Being that this tubing is quite large with open ends, I'd be interesting to hear this antenna singing during a wind storm. Eight whistles
3D SSH III with ZZ4 refl. http://imageshack.us/user/jmsdigital |
#17 | |
I can glue some quarters on the open ends with the queen's face facing in. .
Mes photos: http://s1140.photobucket.com/albums/n574/BOUVAL-OTA/ |
#18 |
Because of the use of 1 inch tubing with 14 ga phasing lines, the NEC program engine is kicking out a lot of Errors and Warnings about that large disparity in sizes. Also, in order to adjust AGT, I had to use a segment size of 5, which decreases accuracy. So I would say the gain figures are probably overstated. However, the relative trend shown is useful.
As is, the antenna is peaking at 812 mhz. Channel 51 goes up to only 698 mhz and channel 69 only went up to 806 mhz. Without a reflector, the peak is at 830 mhz. So it does show that the tubes need to be longer. 9 inches would have the antenna peak at 698 mhz, and the bay spacing would also have to be increased. Also the short reflector to driven element distance is increasing the SWR significantly. NEC file: Code:
CM Bovals 1inch Fat Dipole 4 bay CM AGT = 1.0 (0db) at 585mhz, Autoseg = 5 CM Lots of NEC Errors and Warnings due to 1 inch dipole and 14 ga phasing lines CE GW 24 1 2.875 -0.875 10.5 2.875 -0.875 9 0.0321 GW 25 1 2.875 0.875 10.5 2.875 0.875 9 0.0321 GW 26 3 2.875 -0.875 7 2.875 -0.875 3.5 0.0321 GW 27 3 2.875 0.875 7 2.875 0.875 3.5 0.0321 GW 28 1 2.875 0.875 7 3.275 1.0927e-15 8 0.0321 GW 29 1 2.875 -0.875 9 3.275 1.0927e-15 8 0.0321 GW 30 1 2.875 -0.875 7 2.475 1.0927e-15 8 0.0321 GW 31 1 2.875 0.875 9 2.475 1.0927e-15 8 0.0321 GW 32 1 2.875 -0.875 -10.5 2.875 -0.875 -9 0.0321 GW 33 1 2.875 0.875 -10.5 2.875 0.875 -9 0.0321 GW 34 3 2.875 -0.875 -7 2.875 -0.875 -3.5 0.0321 GW 35 3 2.875 0.875 -7 2.875 0.875 -3.5 0.0321 GW 36 1 2.875 0.875 -7 3.275 1.0927e-15 -8 0.0321 GW 37 1 2.875 -0.875 -9 3.275 1.0927e-15 -8 0.0321 GW 38 1 2.875 -0.875 -7 2.475 1.0927e-15 -8 0.0321 GW 39 1 2.875 0.875 -9 2.475 1.0927e-15 -8 0.0321 GW 40 3 2.875 -0.875 3.5 2.875 -0.875 0 0.0321 GW 41 3 2.875 0.875 3.5 2.875 0.875 0 0.0321 GW 42 3 2.875 -0.875 -3.5 2.875 -0.875 0 0.0321 GW 43 3 2.875 0.875 -3.5 2.875 0.875 0 0.0321 GW 813 1 2.875 -0.875 0 2.875 0.875 0 0.475 GW 814 3 2.875 0.875 10.5 2.875 7.875 10.5 0.5 GW 815 3 2.875 -0.875 -3.5 2.875 -7.875 -3.5 0.5 GW 816 3 2.875 0.875 3.5 2.875 7.875 3.5 0.5 GW 817 3 2.875 -0.875 3.5 2.875 -7.875 3.5 0.5 GW 818 3 2.875 0.875 -3.5 2.875 7.875 -3.5 0.5 GW 819 3 2.875 -0.875 10.5 2.875 -7.875 10.5 0.5 GW 820 3 2.875 -0.875 -10.5 2.875 -7.875 -10.5 0.5 GW 821 3 2.875 0.875 -10.5 2.875 7.875 -10.5 0.5 GW 822 11 0 -10 0 0 10 0 0.1875 GW 823 11 0 -10 1.875 0 10 1.875 0.125 GW 824 11 0 -10 3.75 0 10 3.75 0.125 GW 825 11 0 -10 5.625 0 10 5.625 0.125 GW 826 11 0 -10 7.5 0 10 7.5 0.125 GW 827 11 0 -10 9.375 0 10 9.375 0.125 GW 828 11 0 -10 11.25 0 10 11.25 0.125 GW 829 11 0 -10 13.125 0 10 13.125 0.125 GW 830 11 0 -10 15 0 10 15 0.125 GW 831 11 0 -10 16.875 0 10 16.875 0.1875 GW 832 11 0 -9.975 -16.875 0 10.025 -16.875 0.1875 GW 833 11 0 -9.975 -15 0 10.025 -15 0.125 GW 834 11 0 -9.975 -13.125 0 10.025 -13.125 0.125 GW 835 11 0 -9.975 -11.25 0 10.025 -11.25 0.125 GW 836 11 0 -9.975 -9.375 0 10.025 -9.375 0.125 GW 837 11 0 -9.975 -7.5 0 10.025 -7.5 0.125 GW 838 11 0 -9.975 -5.625 0 10.025 -5.625 0.125 GW 839 11 0 -9.975 -3.75 0 10.025 -3.75 0.125 GW 840 11 0 -9.975 -1.875 0 10.025 -1.875 0.125 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 1.66667e7 0 EX 0 813 1 0 1 0 GN -1 FR 0 1 0 0 585 0
#19 |
I'd like to give it a try, so I have 2 lengths of 29.5" AL tube 7/8" O.D. I can cut them to 29"
Those tubes being that big, should I put them farther than half an inch from the top and bottom elements ? Thank you 300ohm for the modeling, but I don't believe in going longer with the elements. One thing that I'll try though is increasing the ref/ele spacing by an extra 2 inches. .
#20 | |
#21 |
300ohm,
The nec errors? In stampeder's analogy,... his picture essentially shows that using tubing produces the same effect as if squeezing a 4221 'V' element closed to having only a 1" spacing instead of an open 'V' shape: http://www.digitalhome.ca/forum/pict...pictureid=5403. The open 'V' element has 14" of total element length whereas the tubing would only assimilate a 7" total length since the outer surfaces are so close and physically joined. I expected that the frequency range would be out of wack. likely 9" or even 10" tubes may be needed,.. and possibly such lengthened tube lengths would then begin creeping the bandwidths down into the VHF upper frequencies. Maybe taking the reflector out of the equation for now would help with driven element tube performance evaluation. Would a truer [error-less] nec picture of this tubular element design performance be better demontrated if the model was evaluated reflectorless? The reflector size and spacing could then be added later to optimize f/b ratio.
3D SSH III with ZZ4 refl. http://imageshack.us/user/jmsdigital Last edited by stampeder; 2012-06-05 at 12:17 PM. Reason: URL repaired |
#22 |
NEC2 is a THIN WIRE modeling program...to do it "right" each fat tube would
need to be modeled as a cylinder...at which point you'll probably want NEC4. I think the very fat tubes should be providing a better SWR...thicker feedlines are probably needed...try upgrading to AWG10....and if the feedline separation is increased by moving the tubes further OUTWARDS, the Gain nosedive on the lower channels can also be fixed.... |
#23 |
W-G HD-4400 (aka PR-4400) 4-Bay Dipoles w 9 Refl. Rods:
4nec2 results have been uploaded here for comparison. It provides wideband, VERY LOW SWR (under 2.3) performance by using very WIDE bars rather than FAT tubes: http://imageevent.com/holl_ands/mult...winegardhd4400 BTW: Mods to Ken Nist's w4400.ez.nec file were discussed earlier: http://www.digitalhome.ca/forum/showthread.php?t=148569 NO Errors, but lots of Warnings re Sharp Angle/FAT wires....which I ignore... |
#24 | ||
Old, used aluminum lawn chairs are a good cheap source of 1" aluminum tube pieces. A lot of models even have rounded closed ends.
#25 |
When modeling, other than the dimensions, do you have to input the kind of metal used ?
I was thinking that next time my business slows down again I could build another 4 bay with Mclapp's classic M4 dimensions 9.5" x 9". So I ask myself should I use the 1" or the .875" tubes ? With the 1" tubes I can still use the PVC conduit, but with the .875" o.d. tubes which have .77" inside diameter don't know what to use. .
#26 | ||
If not specified, I believe it defaults to either copper or aluminum. Quote:
#27 |
___ When modeling, what metal gives the most gain? Assuming the same specific design.
Personally I think that steel would be the best for the elements. The problem with steel is that it's heavier. ___ Why go with thicker phase lines? If we consider that a 4 bay like a CM4221HD has an impedance of around 225 omms, so going bigger would decrease the impedance more. And we know there's only a few milliamps going thru those phase lines. ___ I think I'll stick with the 1 inch tubes for my next 4 bay build and keep the .875" to build a Yagi for Balm's RF13 .
#28 |
Bouval;
Innovative construction idea! Generally, steel is not the best choice for antennas, especially ferromagnetic steel. I have seen stainless steel used in some commercial yagi designs, but SS has greater losses than AL. On the other hand, the I^2R losses in each yagi element can really add up, but not so much in a collinear antenna like a 4-bay. The phasing lines in a collinear antenna do provide for some impedance transformation, but this impedance transformation varies as the receive frequency changes. I suspect that these fat elements have lower impedance than the Winegard HD4400 modelled by holl_ands. With NEC2-based software, I suspect they would be best modelled as 4 (or more)parallel wires, separated by the diameter of the tubing, joined at the ends.
http://www.tvfool.com/?option=com_wr...e7793e37d4ef93 |
#29 | |||
Wire conductivity Below a wire conductivity table to be used for LD card type 5, wire loading Material Conductivity S/m Perfect 9.90E+99 (lossless) Silver 6.29E+07 Copper 5.80E+07 Pure Alumin. 3.77E+07 Al. 6063-T832 3.08E+07 Al. 6061-T6 2.49E+07 Brass 1.56E+07 Phospor bronze 9.09E+06 Stainless Steel 302 1.39E+06 Quote:
http://www.qsl.net/co8tw/openline.htm
#30 |
BOUVAL and all, be sure to check out the following thread. The info and ingenuity in there is amazing!
Best Metals for Antennas: Performance, Soldering, Welding, Bending, Working We'll keep this present thread focused on modelling and testing your design. |
