AZtrino 1.80 - North American edition for AzBox ME - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2012-05-25, 11:51 PM   #1
DrSat
Default AZtrino 1.80 - North American edition for AzBox ME
Version 1.80 of AZtrino North American edition for AzBox ME is now available for download at AzBox Canada :: Official Canadian distributor for AzBox products under Support.
It includes the following enhancements:
- Option to scan FTA only for TV, Radio or both TV & Radio channels was added and option was renamed from "Scan service type" to "Scan type". This works on all types of scans including satellite, TP and blind scan.
- Option to specify and scan manual PIDS in TP scan. Please note that this feature is currently experimental and although it works well on an empty channel list, it tends to add "ghost" channels once many channels are on the list. As well, scanned in manual pid channels can sometimes make the AZtrino process restart when changing channels. These issues will be fixed with the next version. For now, you may also use this feature to tune in channels which have no Service Descriptor Table (SDT) such as most of the PBS stations on 125W and CBS feeds on 89W.
- Added Scan/use pids option in TP Scan. This controls if PID information for the channel is saved when the channel is scanned in. If this option is off, pids won't be saved when the channel is scanned in so pids will have to be parsed from the SDT every time you tune to this channel. If on, pids are saved when the channel is scanned in so pids don't have to be parsed making it quicker to tune in this channel. This option has no effect when specifying manual PIDS as PIDS will always be saved for these channels.
- Correct directories are now created when connecting a hard disk for the first time for PVR use.
- Optimized speed at which unit shuts down or reboots.
- SDT scan is now aborted when changing channels. This makes changing channels a LOT faster!
- Miscellaneous bug fixes
Best regards,
Dr. Sat
Proud sponsor of the FTA satellite forum
Fier commanditaire du forum FTA
DrSat is online now
FTA Forum Sponsor
