#16 |
Ya the 500 series receivers never seemed to have any issues. Not really sure why the 600 series ones do.
#17 |
My 530 sure had lots of problems.
#18 |
This fall, we will be introducing a new High-Definition On-Screen Guide with PVR expander capabilities. Does anyone have any info. on any of this that's on there website?
#19 |
i would think its a new firmware that will bring out a new Program guide and and enable the external Hard drive for receivers 605 and 630
#20 |
Had the Shaw tech over to put the new LNB on my dish, earlier today. He also did a firmware update, with a zip drive, on all of my 600 series receivers. He also called in a firmware update, via satellite, for my 2 505's and my 401. They expect their new satellite to be operational, by November. Shaw is trying to get their subs to get the new LNB's, sooner than later. They expect a rush, once it gets closer to the changeover date. So far, no problem. When he did the firmware update, one of my 600's was a bit tardy, taking the update.
Winegard PR8800, YA1713, Zenith7777 Preamp, 42" Aquos 120hz, Samsung UP5000 Blu Ray/HDDVD, C/Ku Band, Directv H21, 22. |
#21 |
if you look at the info on your receiver now, what does it say for firmware #? just curious if it's something newer than 7.33
thanks |
#22 |
The USB key that installers use does not update the firmware on the receiver. It simply loads the new xKu channel map which is required with the xKu LNBF. This can also be done via satellite, the USB key is just a shortcut to speed the validation that the LNBF swap was successful and that all channels are available as expected.
Firmware updates continue to be deployed via overnight satellite download when available. |
#23 | |
As usual Shaw employees and contractors are the LAST to know what's happening with Shaw. |
#24 |
Could have swore I read that the launch was being delayed til early 2013?.....anyone else recall reading that?
#25 |
Not quite. Now Dec 30, 2012 (estimated).
#26 |
Figures! I got the same song from the tech support department and their contractor. Selling junk bonds, by the look of it!!
#27 |
here is some info for G1
http://www.telesat.com/satellite-fleet/anik/anik-g1 http://www.satbeams.com/satellites?id=2498 hopefully its sooner then later |
#28 |
Too Late, it is already "Later".....
-- TELUS Employee but I Don't Speak for TELUS -- |
