Hi there,
Would like to change the connectors at the end of the cable where it connects to the LNB. I was wondering if these are good or should I get a different kind. And where can I get them. Noticed that I can post attachments. Can anyone that has that permission post pictures of good connectors.Thanks. |
Thomas & Betts compression connectors are good ones to use, just stay away from the cheap twist on F connectors (the ones that twist onto the coax). Other than that, any compression connectors for RG-6 coax should be fine.
Good advice.
T&B are good. There other makes of good compression connectors. Note that they must be installed with a compression tool (not crimp tool.) They are available at online satellite retailers and Home Depot.
I think I have Thomas & Bettis connectors.
They look like this one. http://www.tselectronic.com/shop/pro...-Connector/301 And the tool I use is this one. http://www.satpro.tv/linearcompressi...ex6xl-cmp.aspx |
