Hi, i came back from mexico and had used my Canon Power Shot camera to film , i finally got it on DVD to work on my Blue Ray recorder , but it will not work on a regular dvd player. I was wondering if there is a program that will convert it for me , preferably free, Thank's.
Might be stating the obvious but does your DVD player play DVD+/-R and if so, did you record on the appropriate +R or -R discs?
You may also have to finalize the disk. If it is not finalized it will play in the original recorder but not in any other machine.
Are you just putting JPEGs on your DVD? If so, not all DVD players will play that type of disk. To be fully compatible, you will need to create a slideshow DVD. I believe Picasa will do this for you.
Link to my TVFool results is in my profile Homepage URL. I suggest others do the same. |
Was it video you shot on your Canon? and if so, is it HD video that this camera shoots?
Then if all is true then that would explain why he can not play HD video on his non-HD DVD player. |
^^^True. I was thinking stills. In this case most modern DVD authoring software will down-convert to SD when you burn a standard DVD.
