Unknown Signals - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2012-05-02, 02:03 PM   #1
Emerald_Boar
Default Unknown Signals
I just got a OPENBOX S9. Did a blind scan and came across the following signals
Galaxy 19 11911 H 10525
AMC 6 11842 V 29659
AMC 9 11843 H 26000
Does anyone know what these signals are?
Read ya l8r,
Al
OTA: DB8 + Y5 2-6 + CM777. FTA: 30W + 72W + 87W + 97W
Emerald_Boar is offline
Old 2012-05-02, 02:44 PM   #2
HDTV Junkee
Sorry -- cannot help you on the AMC 6 sat. signal.
On the Galaxy 19 signal (Openbox 9) -- the TP that shows up is the 12061 H 10525 -- then "failed". RTP International is normally on 12060, 12061 H 22000. For me RTP shows up as under TP 12209 H 22000. For whatever reason, some of my TP numbers (are about 148 SR higher than Lyngsat). But all of the channels come in.
Hope this helps.
HDTV Junkee is offline
Old 2012-05-02, 03:09 PM   #3
Emerald_Boar
@HDTV Junkee
If all of your TP numbers are off by 148. Then your LNB FREQ setting in your BIOS is set wrong.
You have your LNB FREQ set to "universal 9750 - 10750" or "10750". When your LNB FREQ setting should be "universal 9750 - 10600" or "10600". That should give the correct TPs across the board. (or vice versa have things set to 10600 when they should be set to 107500). Then you can use Lyngsat defaults <;
Exactly, My point. There is a signal at those locations. But when i try to scan them in. "FAILURE"
Read ya l8r,
Al
PS. Thanks to fridgeFTA for the image <;
Old 2012-05-02, 03:45 PM   #4
Keith Brannen
All three are most likely data only transponders (either internet or other data streams). Don't scan any channels in on my systems either.
Keith Brannen is online now
Old 2012-05-02, 03:54 PM   #5
HDTV Junkee
Thanks EM.B. I will fix shortly. Setting is currently 10750 Switch ON. Will change to 10600. I guess it was just a coincidence about 12060 TP.
You are probably right in that the TP in question is a data one. No Channels.
FTA Forum Sponsor
