Internal hard drive upgrade for Cisco 8642 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Videotron
Old 2012-04-27, 01:04 AM   #1
jrmtl06
Default Internal hard drive upgrade for Cisco 8642
Since I heard that the new illico operating system will not be compatible with external hard drive, for now anyway at least, I am looking to change my internal hard drive (Cisco 8642).
I need to know if anyone tried a 3TB hard drive, if not a 2TB hard drive. I record only in HD and for 3 person so it takes a lot of space. I'd rather get more right away with a 3TB or 2TB rather than 1TB.
What I need to know: what are the required properties for the best results for any hard drive 1, 2 or 3TB. I don't care how much it cost, what I want is best performance possible.
Look for the info in other threads but haven't seen anything clear for the 8642 yet. Please help!
jrmtl06 is offline
Old 2012-04-27, 09:46 AM   #2
Here's a thread in the Rogers forum on the topic. I believe the limitations, etc are similar. I believe the current limit is 1.5 GB and the WD Black SATA drive is preferred, although most people have been putting in the 1 GB WD Black, which holds about 125-150 hours of HD recordings depending on the bitrate.
http://www.digitalhome.ca/forum/showthread.php?t=122489
Remember that using a PVR as an "archive" is not recommended since it's not a matter of if, but when, you'll lose recordings either via an index issue or HDD failure.
57 is offline
Old 2012-04-27, 11:04 AM   #3
SonyWE610Owner
Get a second recorder. Not all that much more cost.
SonyWE610Owner is offline
Old 2012-04-27, 05:47 PM   #4
jrmtl06
Thanks. I actually already have 2 of them, but believe it or not, they are full and they are not used for archiving. I, and my roommate, like a lot of tv shows, but don't have that much time to watch time, so in the end, we get original shows to watch through the summer months and are usually up to date in the fall.
So the 1.5TB has been tested and is working fine? That is better than just 1TB. That is the equivalent to the 500GB in there now and the 1TB of the external WD My Book AV I got on them.
I really hope eventually we can either have more in there or add the external with the illico 2.0.
jrmtl06 is offline
Old 2012-04-28, 10:42 AM   #5
cm3020prob
Just a thought here.
Maybe the current SARA OS have a 1 To limitation, but we don't know yet with the new "Illico 2" OS, which was apparently built from scratch by local engineers and programmers, and have no link with Rogers's new OS.
Therefor, I doubt the limitations are the same between Vidéotron and Rogers, but also between OS versions. Since the new OS is relatively new, tests with different high-capacity HDDs needs to be done.
CM-3020 with CM-7777
cm3020prob is offline
Old 2012-04-28, 11:14 AM   #6
Sure, feel free to experiment with a larger drive. I believe the worst that typically happens is that only the smaller portion of the drive is recognized - say 1.5 (recognized) vs 2.0 TB (installed). (1.5 TB being the current limit on Rogers with the "old" SARA I believe.) New firmware may have totally different limitations - could be larger, could be smaller...
57 is offline
Old 2012-05-11, 11:23 PM   #7
silverdragon
Default Illico 2?
From what I hear external hard drives aren't going to be supported AT ALL in the near future for illico 2 so you are pretty limited in options right now.
silverdragon is offline
Old 2012-08-16, 10:39 PM   #8
piec2
Default Hard drive sucessfully upgraded on Videotron explorer 8642 HD
I can confirm that upgrading the hard-disk on a Videtron 8642 HD PVR does work, even with the new Illico 2.0. I upgraded from the default 500 GB drive to a 1 TB drive. Here's how my hard disk upgrade on the 8642 went.
First I searched this forum to find out what tools I needed to open the casing. Thanks to the previous people that posted this info: I found exactly the set of screwdrivers bits they were talking about at Canadian Tire (Tamper-Proof TORX, Product #25-6272-8 for 15$). This allowed me to easily open the casing. Only 3 screws to remove that are readily accessible from the back of the PVR.
Once the case is open, I was surprised to see that the green tamper-detect-tape that's supposed to link the disk tray to the actual hard disk was not even taped on (it was only sticking to the hard-drive tray). So I figured nobody would ever know I even opened the casing
I then had to remove the screws holding the disk tray and unscrew the 4 screws holding the hard disk. After that, I simply had to disconnect the SATA cable and power and put the new disk in, reverse the steps for the screws and I was done.
I then replugged everything and connected the power cable.
The PVR went through a countdown (displayed on the front display). It took a while until the count down reached zero. After that it when through a few other status and eventually powered down. Then it rebooted.
It then displayed '0CAP' for a while. I figured it might be formatting the new disk, so I let it go without touching anything.
After a while (a few minutes) it then displayed a few other messages and eventually powered down again. At this point there was nothing on the front display.
I waited a while and nothing seemed to be hapenning, so I decided to push the power button. the little power light came on with the 1080i indicator, but no signal on the TV. I waited a while and nothing was happening.
I then decided to turn the PVR off (with the power button) and unplug it. I then replugged the power.
The unit rebooted and displayed the '0CAP' message again for a few minutes.
Then it displayed 'Ait' for several minutes
Then it turned itself off, but I could hear the disk drive head, so i let it go. After a couple of minutes bingo: the clock appeared on the front panel!
I decide to hit the power button on the remote and the unit displayed 'ALLO' on the front display. Nothing was displayed on the TV.
I let it stand like that for some time before I actually figured out it was my TV that wasn't really synchronizing to the video signal correctly . I turned of the PVR and turned it back on and presto! The Videotron PVR Setup screen was being displayed.
I did the setup and went through the PVR to check the free disk space: 938 GB (115 Hours of HD). Victory!
The hard disk I used to upgrade to 1 GB is the same type of hard disk that was in the PVR: a Seagate 1TB Pipeline HD ST1000VM002 (original drive in the PVR was actually a 500GB model ST3500312CS).
I chose the same model of drive because these drives are made for 7x24 operation and optimized for streaming simultaneously multiple video-streams (so Seagate says anyway). The drive is just as quiet as the old one and cost me $70 on eBay.
I'll record a few shows and if ever I run into any issues I'll come back and post about it.
I'm a happy guy!
piec2 is offline
