Loading. One moment please - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers Cable TV
Old 2012-04-25, 03:56 PM   #1
Kris.urban08
Default Loading. One moment please
Anyone else encounter this "loading. One moment p,ease". Only on certain channels on the Cisco 4642 hd box with new ipg, it happened all of a sudden and I can't figure out why. Channel never loads.
Kris.urban08 is offline
Old 2012-04-25, 04:05 PM   #2
jvincent
I'm pretty sure you see that when an SDV (switched digital video) change is happening. It is possible that the channel being requested can't be made available, which would explain why it doesn't ever load.
Do you have other boxes where you get different behaviour?
Android rocks!
jvincent is online now
Old 2012-04-25, 04:09 PM   #3
Kris.urban08
Should that sdv happen for days? My other nonhd box has no issue
Old 2012-04-25, 04:11 PM   #4
yyzlhr
I see this message for a couple of seconds when the channel has already loaded.
yyzlhr is offline
Old 2012-04-25, 04:13 PM   #5
With SDV you usually get a message similar to "this channel not currently available".
"One moment please" usually indicates that there is an issue with the STB locking onto the channel, which could be STB or signal or connection related (usually a poor connection/splitter). Have you checked your signal strength and S/N ratio?
http://www.digitalhome.ca/forum/showthread.php?t=17719 See also post 10 of the thread for SDV and other issues and how to resolve.
Useful post for those new to the forum - FAQs, Search tips, Optimization, etc:
57 is offline
Old 2012-04-25, 04:28 PM   #6
Kris.urban08
Signal power is 1 and db is 36. That's good no? Plus it worked before. Thisis why I don't pay for this crappy service!
Old 2012-04-25, 04:29 PM   #7
Do a reboot?
57 is offline
Old 2012-04-25, 04:34 PM   #8
Kris.urban08
Done that few times now
Old 2012-04-25, 06:00 PM   #9
Swap the the STBs and see if the problem stays at the connection or goes with the STB. (I realize that's not the greatest test since the other is SD)
57 is offline
Old 2012-04-26, 08:40 AM   #10
ruben308
I don't get this event on my Scientific Atlanta 4250HD box.
ruben308 is offline
Old 2012-04-30, 08:07 PM   #11
Kris.urban08
Ok some more testing and more confusion....took the box to my parents, all channels worked no problem, Took it upstairs at my house and some channels don't work again, however, upstairs my sd box shows all channels
Old 2012-04-30, 11:43 PM   #12
Different STBs can require different signals or be affected in different ways. If you have a cordless phone, these can cause interference if there is a poor connection nearby. Try unplugging the "main" phone. I assume you're testing the signal on the affected channel? Call Rogers.
57 is offline
Old 2012-06-01, 09:20 PM   #13
Kris.urban08
Am I the only one having this problem?? None of the suggestions fixed the problem...any others?
Old 2012-06-01, 11:48 PM   #14
Per the last line of post 12 - Call Rogers? They can check your signal, etc remotely and schedule a visit if necessary.
57 is offline
Old 2012-06-03, 07:26 PM   #15
Kris.urban08
That is not an option
