Sony BDP-S590/BX59 Blu-ray - Canadian TV, Computing and Home Theatre Forums
Old 2012-04-23, 06:05 PM   #1
HenryWiggers
Default Sony BDP-S590/BX59 Blu-ray
Just got this unit last week and still learning. USB in front. I loaded some TV shows onto a USB stick from iTunes. Put in the stick and found the files (mp4). The manual shows mp4 is a playable file. When I chose one of the shows and hit play I got `Corrupt or Unsupported file`. I`ve tried 2 different sticks and get the same results. I`m not sure if I should have put this in the computer section or not. I might try if I don`t get any results here. Thanks.
HenryWiggers is offline
Old 2012-04-23, 07:39 PM   #2
cooper83
Are the shows purchased from iTunes?
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700
cooper83 is offline
Old 2012-04-26, 10:06 PM   #3
HenryWiggers
Thumbs up
Yep. All purchased from iTunes.
Old 2012-04-26, 10:23 PM   #4
cooper83
Can only be played on devices that support iTunes then: computers, iPad, iPhone, iPod Touch, AppleTV.
cooper83 is offline
