Powershot s95 vs s100 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2012-04-20, 12:02 PM   #1
DouglasTech
Default Powershot s95 vs s100
Anybody has any advice on which one I should get?
I'm not sure the extra money for the s100 is necessarily worth it?
DouglasTech is offline
Old 2012-04-22, 06:17 PM   #2
BGY11
If you can afford it, I'd suggest getting the S100. Although it may not look that much different based on the specs, the sensor is improved, as is the image processor (the DIGIC V chip). You also get a bit more zoom, and 1080p (24fps) recording on the S100.
That said, if budget is a concern, the S95 would still be a decent camera.
BGY11 is online now
Old 2012-04-23, 12:56 PM   #3
DouglasTech
OK thanks BGY11,
I think I'll follow your advice and simply wait for the s100 to be on sale.
Thanks again.
Old 2012-04-23, 10:10 PM   #4
BGY11
As luck would have it, I played around with an S100 today and I did like it overall; though it was little too small for my tastes (I had my eye set on the G12, and ended up snapping one of those up instead). I was impressed with the responsiveness and quality of the S100, and stand by my belief that it would be worth paying a bit extra for it over the S95.
BGY11 is online now
