Version 1.75 of AZtrino North American edition for AzBox ME is now available for download at AzBox Canada :: Official Canadian distributor for AzBox products under Support.
It includes the following enhancements: - 1080p and 1080i NTSC resolutions have now been fixed - NTSC is now enabled by default when installing the firmware or even after a factory reset! - EST timezone selected by default - Numerous blindscan fixes, now works on C-band 5150 and Ku-band 10750 systems in addition to Universal 9750/10600 - Added support to specify start and end frequencies for blind scan - Added support to specify polarisation for blind scan. Either H, V or Both are available as options - Added 22Khz Tone option to specify if 22Khz should be on, off or be switched automatically for universal LNBF's This is just temporary for now as we will have this parameter controlled automatically based on antenna setup in future versions - Under TP scan, changed frequency and symbol rate fields to 5 digits instead of 8 - Fixed cosmetic bug where 2/3 FEC rate was being displayed as 3/2 Please let us know if you have any issues in regards to this new firmware version. Best regards, Dr. Sat |
Thanks for the Update. Will download and test later.
Version 1.77 is now available from the same above source. It includes enhancements in regards to blindscan functionality.
Regards, DrSat |
