In case you didn't notice this from Hugh's twitter at the right:
http://api.viglink.com/api/click?for...13346690476141 It would appear that WMC7 is static and may not be developed or updated. As for this "media pack": Features beyond that of WMC7? Co$t?
Srvr:ASUSF1A75-VPro,RadHD6000,A6-3670K,WD2TB,W7Ult NPVR,5.1,2xHaup2250MC,ATI650,CM7777,WGHD8800,5clts |
oh well, was fun while it lasted.
The trend seems to be away from HTPCs and toward more profitable streaming solutions or encumbered downloads. It's no accident that Google killed SageTV at about the same time it started Google TV. It's also no secret that the big media companies (Sony, etc) want to kill off HTPCs and MS is in bed with them. Killing WMC makes sense from that perspective. I also expect that MS was betting on making WMC and it's proprietary encryption technologies more pervasive. MS failed in that regard so the profit motive for keeping WMC is gone. In addition, the proposed Canadian copyright law will make some uses of WMC and HTPCs illegal. How many failed products does that make for MS now?
I predicted this move in a post months ago, and I believe it's a good thing for many reasons:
- It allows Media Center to be updated more frequently than the OS. - Microsoft doesn't need to license certain codecs (e.g. Dolby AC3) in the OS by default any more if they're only there for Media Center users. This drives the cost of producing Windows down for the relatively small market (especially when compared to the massive Windows market). - With Media Center no longer being completely free, the commercial HTPC market can open up again. I think Media Center being free (and being as good as it is) was really damaging to companies like Snapstream and Sage TV. Most importantly, I think that with Metro as a primary Windows interface, the need to create additional "specialized 10 foot interfaces" is ending. Just create an app that can be completely controlled with keyboard events (arrow keys, enter, etc) and a user can navigate between them using a remote control. You could have two Metro applications to do what Media Center does: a XBMC-like app to play local media files and manage local libraries of content, and a TV recording app that interfaces with TV tuners and creates the resulting files on your local disk. Then app like Netflix or Hulu would "just work" without the need to create a "plugin" for your HTPC app of choice. They would all work together because they would all be Metro apps. And best of all, it would be much easier to write those apps with frameworks like WinRT, so the app developer won't need to spend all that time writing custom interface elements that work well on a TV. |
Metro could certainly have the unintended side effect of changing how HTPC interfaces work. IF (that's a big if) Windows developers start creating Metro interfaces for their media apps AND Metro supports media remotes, the need for media center interfaces will disappear. I don't see that convergence taking place for some time though. Android apps that allow control of Windows software have appeared so Metro apps probably won't be far behind. The currently available apps are very disappointing though, mainly for controlling HTPCs from a phone or tablet.
WMC has been "dead"(static) for years.
People use it for the same reason they climb Everest. "Because it's there". They become familiar with it and to use something else is too much effort. Now the 3rd party MC apps, which are FREE (or donnation) can get thier attention. They have much more features to offer and you're not locked into proprietary extenders. btw: there is another article regarding energy wasted by PS3s and Xboxes sitting idle in America back in Hugh's twitter column. Crappy little P4 extenders are smart enough to sleep and wake up even using XP. Why would you need two MC apps(XMBC+WMC) to do what one is fully capable of doing. NPVR has Netflix intergrated I'm not sure 'bout MP or Myth. Why stack individual apps when one(1) can do it all with one remote. The time for users to dump WMC has been here for a while, now the lights are flashing. The one thing that does concern me about this what may be the effect on the Times-Trib EPG data both used by Schedules Direct and MC2XML but essentially a MS project.
I can't see the rationale for rerquiring the "Pro" version of Windows 8 when WMC is really a consumer product.
I agree, bundling it with "Ultimate" would be a more logical choice. I wouldn't be surprised if MS killed off Win Ultimate for Win8 as well.
MediaPortal can do just about everything that WMC, NPVR and XBMC can do. Development is still active as well. It's pretty much as capable as SageTV was before it was axed by Google. MP suffers from two major drawbacks. One is a reputation for being unstable. That is no longer true since release 1.0 (some time ago.) The other is that it is difficult to configure. That is still very true. I like the extensive configuration ability but it also needs to be PnP for basic use. OTOH, WMC and XBMC are pretty much PnP at the cost of limiting configuration ability.
#9 |
@ScaryB
I aggree, I was bamboozaled by MP. and back in '09 WMC didn't want to work with my hardware (using XPpro with MC) But NPVR is pretty easy to set-up then tweak and master. After a little over a year post GB-pvr it's very stable. And for remote access I just point a web browser to h t t p:/<my IP><port#>guide2.aspx and I can do anything from schedule recordings to stream live TV
#10 | ||
This may seem like a small thing, but now that streaming video makes up the majority of my TV viewing (with OTA content filling in the rest), the interfaces to Netflix and Hulu are a big deal to me. And I love how you can use Kinect to navigate Hulu with your voice. Quote:
You can also set your primary WMC box to go to sleep and it will transparently "wake up" when a extender nudges it (using a magic packet) or if it is time to record a TV show. This would allow the user to select one product independently from the other. Some products like XBMC have a excellent UI, but the authors (or the project) may not have interest in dealing with TV tuners and guide data. I thought this benefit was obvious, so I didn't state it in my earlier post. |
#11 | |
#12 | |
Looks like they are finally going to spend some time updating it
http://news.cnet.com/8301-10805_3-57...automatically/ Quote:
#13 |
I'm hoping that it gets split into a bunch of little metro apps so that 3rd parties can add their own app to the mix by "just writing a Metro app" rather than having to use some oddball API like they currently have with Media Center.
The statement j0dert3r quoted suggested that this may indeed happen. I also think that if you're using Win8 as your PVR that Storage Spaces will be awesome. |
#14 | ||
She unfortunately misread the blog. In the 2nd paragraph from her article that j0dest3r quoted, the original blog post states that about Windows 8, not Media Center. Media Center is simply being kept on life support and the blog post author clarified in the comments that the marginal cost for the Media Center Pack for Windows 8 Pro may be in the single digits (the Pro Pack will likely cost much more).
http://blogs.msdn.com/b/b8/archive/2...windows-8.aspx Quote:
#15 |
Ahh crap! You just busted my bubble LOL!
Sounds more like they are going to include MC just to shut us up and hope that metro apps end up taking its place somehow. Grr!! Does the metro screen work as well with a remote control like MC does? Doubt it! |
