Looking for a new BTV 5900 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Where Can I buy and general buying discussions
Old 2012-04-13, 01:06 PM   #1
EarlyAdopter
Default Looking for a new BTV 5900
Hi. Anyone know a dealer anywhere in Canada with a warrantied 5900 complete with LMB and dish? Really want a NIB unit, not a suspect item off kijji. It's for a cottage and I don't need a HD unit for the purpose.
EarlyAdopter is offline
Old 2012-04-13, 07:52 PM   #2
Pinza
You will NOT get a new unit, they have not been made for many years.
You will/should find a refurbished unit out there.
As for the Dish/LNBF, that should be an easy one to locate off Kijiji or FleaBay etc.
Pinza is offline
Old 2012-04-16, 01:10 PM   #3
spuggy68
Why not buy a 6131, and a small external hard drive that you use at the cottage? Your TV would need to either have HDMI / S-Video, or Composite Connectors for this option, but you don't have to worry about a dated receiver. Many of the small WD 500Gig or less Hard Drives that don't require external power work great on 6131's, plus if your planning on recording many items at the cottage, you will have much more recording time.
Because the 6131 is actually a HD Receiver, if you have HD at home, you will be able to still watch some HD Channels (down converted) that are not available on SD Receivers.
Hope this helps!
spuggy68 is offline
