MythTV 0.25 Released - Canadian TV, Computing and Home Theatre Forums
Old 2012-04-11, 03:40 PM   #1
stampeder
Default MythTV 0.25 Released
I'm sticking with 0.24 for now while I read up on the many new features in 0.25:
http://www.mythtv.org/wiki/Release_Notes_-_0.25
stampeder is offline
Old 2012-04-11, 03:59 PM   #2
OTAJuncqui
Does this mean windows is supported without some kind of "kitbashed" build. I haven't had much success with those.
And what are the remote capabilities?
Srvr:ASUSF1A75-VPro,RadHD6000,A6-3670K,WD2TB,W7Ult
NPVR,5.1,2xHaup2250MC,ATI650,CM7777,WGHD8800,5clts
OTAJuncqui is offline
Old 2012-04-11, 05:11 PM   #3
rsambuca
Are myth upgrades usually painfree? I have never had to go through a version upgrade before, but I would hate to have to fiddle with my current setup (although I probably won't be able to stop myself from upgrading). We only have one TV in the house, so it would be rather 'inconvenient' to have it out for any lenght of time.
rsambuca is online now
Old 2012-04-12, 07:33 PM   #4
rpr
The difficulty of the upgrade is dependent on lots of things, OS and hardware being the most likely area for problems. The new version may have dependencies that your Linux distribution may not have, and your hardware may or may not be supported, depending on the age. I can't really speak to any upgrade issues as I am always running pretty much current trunk revisions (usually update once a week or so) and I haven't had any real show stoppers, and in a few cases I've helped to find bugs.
As for Windows, again I can't speak to it as I don't use it, but from what I've seen on the commits list, there has been a fair bit of work to make it easier to compile.
I'm not sure what is meant by 'remote capabilities'. Are you talking about remote controls, or remote viewing of some sort?
Tom
rpr is offline
Old 2012-04-12, 08:20 PM   #5
rsambuca
Well, couldn't resist. I upgraded today and it seems to have worked. I had to delete some existing theme files first, and then had to run some database update. Seems to be working so far. Just missing the theme I was using before, but I assume I can find it somewhere.
Old 2012-04-12, 09:11 PM   #6
OTAJuncqui
@ rpr
By remote capabilities I mean access from another PC(eg: at work) via an internet connection to manage(schedule) recordings and stream live TV and media.
Old 2012-04-13, 07:56 PM   #7
stampeder
OTAJuncqui you can administer the Mythbackend(s) from other machines with MythWeb and/or phpmyadmin.
Check out the MythTV Wiki.
Old 2012-04-24, 09:06 AM   #8
roger1818
Also, I seem to remember reading that mythtv-setup can be run on any frontend and it will update the configuration of your backend.
roger1818 is online now
Old 2012-04-29, 11:59 PM   #9
Reed Solomon
I just ssh -Y to my mythtv backend and run it remotely via X.
Reed Solomon is offline
