PIP output to TV - Canadian TV, Computing and Home Theatre Forums
Old 2012-04-08, 03:57 PM   #1
mpovolo
Default PIP output to TV
My TV does not support this feature. Looking for a receiver or some box that will allow me to display two sources on my tv. Wanted by cable and htpc to be able to display on my tv and be able to easily choose one as the main when I want. Any ideas.
The sources are hdmi and could be component if I want.
mpovolo is offline
Old 2012-04-08, 07:13 PM   #2
mr shady
I kno rogers hdpvr and sd pvr support this where you can watch pip easily!
mr shady is offline
Old 2012-04-08, 09:22 PM   #3
mpovolo
I know Rogers does pip for cable. I want pip for Rogers with a connection from my htpc.
mpovolo is offline
