Streaming to BB playbook via HD Homerun - Canadian TV, Computing and Home Theatre Forums
Old 2012-03-25, 12:13 PM   #1
Jakeman3
Default Streaming to BB playbook via HD Homerun
I've done some research myself and can't seem to find anything..
Does anyone know of any app that would allow the BB Playbook to receive streaming from the HD Homerun? Maybe a SageTV android app or something..
I couldn't find anything... Anyone have any idea's?
Jakeman3 is offline
Old 2012-03-26, 10:22 PM   #2
OTAJuncqui
I'm not familiar with BB but you could look at NextPVR. It can stream to android , iphone and jailbroken ipad. It has VLC intergrated to it's NEWA(New Enhanced Web Administrator) feature. If you can get VLC on your BB you should be able to recieve a stream but it won't be full HD cuz 1/2 hr of HDTV is 3-4gigs and VLC streams that down to 50mb. Or it may be possible to set your BB up as a client on your LAN. I just checked npvr support and yes you can use NEWA with BB curve and opera, maybe playbook as well.
Srvr:ASUSF1A75-VPro,RadHD6000,A6-3670K,WD2TB,W7Ult
NPVR,5.1,2xHaup2250MC,ATI650,CM7777,WGHD8800,5clts
OTAJuncqui is offline
Old 2012-03-31, 05:55 PM   #3
j0dest3r
WinTV extender works with the Hauppauge stick.
j0dest3r is offline
