Nimiq 6 (New Bell Satellite) Discussion - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Bell Canada Enterprises (BCE) > Bell Satellite TV
Old 2012-03-19, 03:57 PM   #1
frenchhomer
Default Nimiq 6 (New Bell Satellite) Discussion
On March 15th Nimiq 6 arrived at Baikonur in preparation for a May 17th launch on the Proton-M/Briz-M vehicle. Nimiq 6 will be placed at 91.1.
frenchhomer is offline
Old 2012-03-19, 04:39 PM   #2
primehifi
I forget the upshot of this sat but I seem to recall reading that it provides no additional bandwidth, so no real gains from this sat, besides replacing the current bird there?
Would love to be corrected on this.
primehifi is offline
Old 2012-03-19, 05:39 PM   #3
Pinza
You are correct, nothing new, just more powerful than the 2 birds at 91 degrees right now.
The footprint will also change and cut off most of the US.
Pinza is offline
Old 2012-03-19, 05:43 PM   #4
jdevlin
Satellite Name: Nimiq 6
Status: planned
Position: 91° W (91° W)
Norad:
Cospar number:
Operator: Telesat Canada Ltd.
Launch date: 30-Jun-2012 (Estimated)
Launch site: Baikonur Cosmodrome
Launch vehicle: Proton M
Launch mass (kg): 4745
Dry mass (kg):
Manufacturer: Space Systems Loral (SSL)
Model (bus): LS-1300
Orbit: GEO
Expected lifetime: 15 yrs.
Call sign:
Beacon(s):
Details:32 high powered Ku-band transponders. Bell TV has agreed to fully lease this new satellite for its lifetime to serve the fast-growing number of Bell TV subscribers across Canada.
Beams:Ku-band Canada beam (predicted)
Nimiq6 from Telsat.
http://www.telesat.com/satellite-fleet/nimiq/nimiq-6
jdevlin is offline
Old 2012-03-19, 05:47 PM   #5
Pinza
See that is what I just said. Nothing new.
Pinza is offline
Old 2012-03-19, 06:08 PM   #6
primehifi
Pretty poor planning and spending of money on their part, no?
Old 2012-03-19, 07:00 PM   #7
ChannelMaster
Hummm. Is it true that Bell enjoys a "fast growing number of subscribers" over satellite?
Going digital with a pair of CM4228a pointing due south fed into a Winegard SD-3700 antenna coupler @220 ft
ChannelMaster is offline
Old 2012-03-19, 07:12 PM   #8
scrooloose
Nimiq 1 is 13 years old, so it's time for a replacement. It's actually good planning.
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub
scrooloose is offline
Old 2012-03-19, 07:32 PM   #9
nic78
No more Bell TV for snowbirds in Florida. Yes it is not allowed by Bell but there well be thousands of upset subscribers, and possible cancelled subs.
nic78 is offline
Old 2012-03-19, 08:09 PM   #10
Pinza
Lots of cheap Receivers on Kijiji then.
Pinza is offline
Old 2012-03-20, 08:15 AM   #11
Blackloz
Thankfully I will still be good to go with the standard Dish 500.
Blackloz is online now
Old 2012-03-20, 08:58 AM   #12
MCIBUS
Question
Looking at that map, why does the singal reach so far into the Atlantic Ocean?
Also with a stronger singa;l does this mean less chance of rain fade?
MCIBUS is offline
Old 2012-03-20, 09:31 AM   #13
nic78
It will help to some degree but it would be impossible to totally eliminate rain fade. The big cause of rain fade I noticed when I had Bell TV was not the weather locally where I lived but a down pour at the uplink center in Toronto. Bell should have a second uplink center else where in the country.
nic78 is offline
Old 2012-03-20, 12:51 PM   #14
primehifi
Yes I understand that n1 is dying but to put a new sat up with the same bandwidth as their current sat at that position, during a time when they're so strapped for space, to me seems like poor planning.
They've basically said "well, we have no bandwidth now, so lets have no extra bandwidth for the next 14~ years, unless we spend more money again on another launch for two birds or a replacement at 91".
Old 2012-03-20, 01:27 PM   #15
ScaryBob
There is no more bandwidth available for DBS at 92. Satellite frequencies are regulated, just like any other broadcasting. Bell was assigned a third satellite at 72 but sold the entire capacity to Dish network in the US. Bell has opted, instead, to use more compression and better compression technology (MPEG4.) The higher power provided by N6 may also allow Bell to use more efficient error correction methods and add more channels.
ScaryBob is offline
