itunes download - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2012-03-14, 11:48 AM   #1
boaddict
Default itunes download
im trying to download itunes, it says i have sucessfully downloaded it but then when i go to open it i get itunes software agreement, when i click agree. it disapears and nothing happens.
any suggestions?
boaddict is offline
Old 2012-03-14, 12:19 PM   #2
DSgamby
What Operating System do you have?
DSgamby is online now
Old 2012-03-14, 12:49 PM   #3
boaddict
windows 7
boaddict is offline
Old 2012-03-14, 12:50 PM   #4
DSgamby
Are you running as an Admin?
EDIT: Found this at another forum
Answer:
1. On the Start menu, click Control Panel.
2. Click "Hardware and Sound" in Control Panel Home then click Personalization.
Alternately, in the Classic View of Control Panel, click Personalization.
3. Click Display Settings.
4. Select a resolution that is higher than 1024 x 640 and is supported by the display by adjusting the slider.
5. Click OK.
6. Your screen may flash briefly and you may see a message asking you to confirm the settings. Click Yes if the image on screen looks normal. Note: If the screen looks dark or distorted, wait 15 seconds for the screen to revert to it's previous state.
Last edited by DSgamby; 2012-03-14 at 12:56 PM. Reason: Found info on the problem. Hopefully
Old 2012-03-14, 04:19 PM   #5
boaddict
that didnt work for me either but ty.
so i downloaded the version i had b4 now it says "the i tunes application could not be opened. you do not have enough access privileges for this operation."
any ideas
boaddict is offline
