acutrac22 pro - Canadian TV, Computing and Home Theatre Forums
Old 2012-03-10, 06:49 PM   #1
redneckfromnb
Default acutrac22 pro
has anyone got a clue what happened to the acutrac.it was working great and all of a sudden when i attach it to any legact lnb to dial in on a satellite,all i get is overcurrent no matter how many wires i try,is there a way to reset these?
redneckfromnb is offline
Old 2012-03-10, 07:29 PM   #2
gzink
Been a while and I use it with SD and also have my own custom lipo external battery pack, but could this be related to the battery? If it will work without the pack take it out??
The pack has circuit breaker?in it. Perhaps a shorted cell??
gzink is online now
Old 2012-03-11, 08:22 AM   #3
redneckfromnb
no the battery is fine,both bar grafts are showing until i hook it up to a lnb then it dont matter how many jumper wires i try it shows over current
Old 2012-03-11, 02:21 PM   #4
gzink
I believe I also got this when one of the settings was inadvertently set. I would check all settings on the menus...again!
gzink is online now
Old 2012-03-11, 02:30 PM   #5
JoeLouie
Any chance you have a spare LNB to try?
JoeLouie is online now
Old 2012-03-12, 05:58 AM   #6
redneckfromnb
ive already tried at least 6 new lng,if i let the battery go completely dead do you think it will reset
Old 2012-03-12, 07:58 PM   #7
gzink
I can't get to mine but I didn't think the bars show until you hook it up and the receivers provide power. I think you may have a setting on in the menu which telss it ti provide power. Then the battery and the power from the receiver are screwing it up. You only need the battery when not hooked up to a sat receiver.
Hope I'm not sending you in the wrong direction.
gzink is online now
Old 2012-03-12, 08:10 PM   #8
Pinza
Is it possible that the receiver you are using to power it was last used on DPP, therefore sending out a different voltage.?
Pinza is offline
Old 2012-03-13, 05:38 AM   #9
redneckfromnb
no i dont even have it hooked to a receiver,i use it on the battery pack
