Installing Bi-Directional Amp...too much ? - Canadian TV, Computing and Home Theatre Forums
Old 2012-02-27, 05:39 PM   #1
weehaggis
Default Installing Bi-Directional Amp...too much ?
I'm thinking of installing a Bi-Directional booster.
If the amplification is too much, is there some sort of inline filter I can use to reduce it ?
LG-42PC5D,Antennas Direct DB8,CM0068C Preamp,CM9512A Rotor,CM 9537 Remote Control ,Tii - Gas Surge Arrestor
weehaggis is offline
Old 2012-02-27, 05:42 PM   #2
If you need an amp, Rogers will supply the appropriate one, or correct the signal, all at no charge. To reduce signal, it's possible to simply add a splitter - 2-way 3.5 dB, 3-way 5-7 dB depending on type. The unused legs should have a terminator on them.
57 is offline
Old 2012-02-27, 07:53 PM   #3
mr shady
you can use a pad (to reduce signal they come in 3/6/10/20's) this is better option than using a spliter can be installed on a amp on a dstb mdm where ever needed!
mr shady is offline
