Trying to find a cable splitter - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable
Old 2012-02-20, 06:04 PM   #1
Positive Climb
Default Trying to find a cable splitter
Hi all,
I'm trying to split the cable going into my internet modem so I can use it for a TV also. I saw this splitter at Home Depot and I'm wondering if it works well? IDEAL 2 Way Digital Cable TV Splitter (Model: 85-132 | Internet/Cat: 941322 | Store SKU: 1000449513) $3.98
thanks!
Positive Climb is offline
Old 2012-02-20, 07:00 PM   #2
Shaw provides free splitters - go to one of their outlets and they'll supply the proper one - 5-1000MHz minimum and two way. With a modem you should not have a splitter on that line as the modem should be the first split coming into your home. You might get away with it, but then again you might have problems. Call Shaw and have them do it properly.
That splitter you mention is NOT recommended.
57 is offline
Old 2012-02-20, 09:30 PM   #3
JamesK
I have 2 splitters on my cable modem line. A 2 way in the living room where my main TV is and a 3 way in my "office", where I've got my cable modem, phone terminal and another TV (actually computer monitor) connection. All splitters and cables were installed by Rogers and everything leading to the cable modem has a red tag on it. I also have a 2nd feed in my bedroom, which serves only a TV.
JamesK is online now
Old 2012-02-20, 11:40 PM   #4
When the service provider does the installation they have special splitters that they can use that have specific losses per side/leg of the splitter. As stated, get Shaw to do this for you - they'll use the correct equipment and check the signals.
JamesK, what works for you may not work for someone else.
57 is offline
Forum Sponsor
