FTA newbie for fun & pleasure - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Free to Air Satellite Television
Old 2012-02-14, 09:31 PM   #1
kovalev
Default FTA newbie for fun & pleasure
I actually have Bell services (internet, sat, phone)
my brother in law gave me is old viewsat, and a spare lnb
So i have available a extra "kinda" bell size dish, bell compatible spare lnb, with the viewsat. So i tought i could give it a shot to see what can i get with FTA. No high expectation, just for hobbie and fun
Any suggestion to help me out !
p.s. my Bell installation was done by Bell,
so no clue how to find any satellite either for Bell at that time
or now for FTA
kovalev is offline
Old 2012-02-14, 11:22 PM   #2
We do not discuss getting Bell with FTA on this forum since that's piracy (doesn't matter that you subscribe). I suggest you start by reading the stickies at the top of the FTA forum for FTA Newbie-type info.
57 is offline
Old 2012-02-14, 11:26 PM   #3
kovalev
I am french speaking, I will try to explain again,
I am doing only legal stuff !!!
Just would like to try REAL FTA, NO illegal stuff !!!
Sorry if i mislead
want to try to receivre free to air for fun !
(je parle du vrai FTA, je ne veux rien faire d'illégale, merci )
kovalev is offline
Old 2012-02-15, 06:04 AM   #4
Pinza
I could be wrong but think you will get these with a "Bell" sized dish.....
http://www.digitalhome.ca/forum/showthread.php?t=151311
Someone will correct me if I am wrong, I hope.
Pinza is offline
Old 2012-02-15, 08:13 AM   #5
Kraven
@ Kovalev--> Avec une secoupe de 20pouces, il y a pas grand chose que tu peux recevoir avec ca. Seulement les trans. d'haute puissance va rentrer (ex: PBS, peux etre des feed d'NBC aussi).
Sur le site de Dr Sat, il a un liste de poste disponsible. Verifie ca pour voir les canaux tu amerais avoir.. pis apres, va a satbeams.com/footprints. Ce site va te dire quel grosseur de secoupe ta bessoin.
En bref, je dirais minimum 33pouces, mais la majority ici qui a une secoupe Ku est de 39pouces.
Cheers, K
Kraven is offline
Old 2012-02-15, 08:34 AM   #6
kovalev
The only things that i don't have yet is the dish,
(the spare lnb, used to be for a Bell installation)
so if I can add a well sized dish, to my actual lnb and viewsat that would be cheap to give it a try.
kovalev is offline
Old 2012-02-15, 08:41 AM   #7
Kraven
The only thing you'll get with the BXV lnb are US locals on 118 and 61.5 which are ITC for now.
You'll need a bigger dish, linear lnb and option motor for everything else.
Cheers, K
Kraven is offline
Old 2012-02-15, 08:52 AM   #8
cyberham
You can get a brand new FTA dish with all mounting hardware starting at about $69. Maybe you can even find it locally to avoid shipping costs since you're near Montreal. It's worth the cost just to try out FTA to see if you enjoy playing with this activity.
By the way, I see listed on kijiji in Montreal an 8-foot C-band dish just waiting to be taken from a backyard. Often these can be had for low or even no cost. Somebody should get that nice mesh dish!
cyberham is offline
Old 2012-02-15, 08:59 AM   #9
classicsat
Get a 36" dish and Ku LNBF. That is the best start.
I have one (an old one from when Bell first launched - it has seen better days), I use it with an ex-pirate SV4000, to play with, primarily on 97W. I have several Ku LNBFs (only one new one, the rest from the late 1990s).
I admit I took the dish down for major home renovations, but don't yet have it installed back.
Later on, you may want to get a motor, or experiment with a multi LNBF setup, with a DiSEQ switch.
classicsat is offline
Old 2012-02-15, 08:29 PM   #10
kovalev
@Kraven
What means "ITC" ??? merci
kovalev is offline
Old 2012-02-15, 09:11 PM   #11
frubsen
ITC = In the Clear
it means the channels are not encypted
frubsen is offline
Old 2012-02-16, 05:49 PM   #12
kovalev
LNB simple or LNB Double ???
what doest it change ???
kovalev is offline
Old 2012-02-16, 05:55 PM   #13
Pinza
A single LNB has one output, a Dual has two outputs.
Each LNB will only see 1 Satellite. The single will feed 1 Receiver, the Dual will feed 2.
Pinza is offline
Old 2012-02-16, 07:44 PM   #14
kovalev
When the weather starts to be more warmer, I will probably climb my tour and add a new dish for FTA,
It will be close to my Bell Dish
Will Bell, ask to check my FTA installation ?
kovalev is offline
Old 2012-02-17, 07:46 AM   #15
Pinza
No, it has nothing to do with Bell.
Pinza is offline
FTA Forum Sponsor
