#16 |
#17 | |
Corporate Supporter
60' Delhi tower,91XG,Y13-10,DB8,Tin Lee Traps,CM9521A,CM7777,CM7000,Winegard RC-1010 & HDA200,Samsung 32 LCD,2 WTV950Q Twinntech supports Digital Home |
#18 | |
This will settle for zero cost whether reducing cable length will help the received signal strength of LPB. |
#19 |
Wilspin,
You mean how to determine all of the parameters? By using the PC Based Tuner, Prof 7500, a Windows PC (Laptop), and Crazyscan. Basically ya wind up with a poor man's spectrum analyser, with Blindscan capability. The program reports all the parameters from the frontend for you. You can also send the entire Transport Stream to TSReader for further analysis, and from there stream a particular channel to VLC for Playback. Very Cool, highly recommended!
uhf/vhf combo rotor chimney mount homebrew vhf hi hpf ap-8700 preamp 4way split lg lcd dtt901 pctuner mythtv |
#20 |
cyberham,
the setup I just described above would be very handy in a case like yours, Because the program actually does an RF sweep of the entire IF spectrum, you'll get a visual indication of the RF Signal strength across the band. You could compare a sweep as is down the entire length of your feedline, then sweep again with the tuner closer to the antenna, and compare the overall levels, and ability to lock known transponders. After a while you get a feel for what it takes, SNR wise to lock different types of feeds. If you really want to know what it takes, download this spreadsheet which is useful to compare the measured C/N versus the known parameters a certain feed is using, you can then determine exactly how much margin you have in your system for that feed. http://www.32apsk.org/wordpress/?p=240 Personally I think something was wrong with that transponder the other nite. I'll try and check it out again later tonite, see if it still acts up on me here. If it does there may not be anything really wrong on ur end.
#21 |
@MT--> It seems you recommend the Prof7500, where did you get it? I cant find it anywhere, including *bay.
Cheers, K |
#22 |
ur right I don't see them at DRsat's site. I wonder if they might sell them but just don't advertise it?
http://proftuners.com/prof7500.html It's PCI cousin is the 7301. PS - Just because I have one doesn't mean it's the best card out there. Honestly, I wouldn't really know because it's the only one I've ever had. But I have been happy with it.
#23 |
#24 |
I am able to receive LPB on my Pansat 9200HD (with the S2 extension) and a 1-meter antenna. Thanks for the info.
#25 |
#26 |
Corporate Supporter
This TP is weak. How can i improve it?
#27 |
1. Reduce losses in system: shorten dish-to-receiver cable length; change cable to lower loss type, eliminate any diseqc switches between LNB and receiver, confirm cable connectors are good quality and installed well.
2. Increase received signal level: orient dish precisely both azimuth and elevation; change LNB for a model with lower noise figure, higher gain; increase dish size. 3. Give up and try for 125W Ku PBS where there is a good assortment of PBS stations also. |
#28 |
Corporate Supporter
Tried 1, 2 to no avail. 3 is not an option as 119 and up are too low on the horizon here.
#29 |
PBS North Carolina is currently ITC and available from 61.5W Ku. That local could disappear any time, but it's easy to get and strong right now with a circular LNB. Any chance to get OTA PBS from Rochester or Buffalo? You've got a nice tall tower for a high gain TV antenna. Ever thought of going to C-band? I'll bet drsat could fix you up with necessary hardware. I presume PBS is available on C-band.
#30 |
Corporate Supporter
U got some details on PBS @61.5? Rochester PBS is not reliable this time of year, Buffalo is rock solid always. I just like multiple choices. Spoke with DR Sat last week about large dish. we will see.
