Hi all,
Please share your thoughts on this question. I have an 8 bay pointed North connected to a CM7777 that pulls in wanted distant stations as far as 72 miles. If I install driven elements on the South side of the same antenna can I expect to get stations that are 180 degrees away from the North? Will the elements interfere in some way? Thanks, Mac060 |
#2 | |
To avoid the loss, you could run two coax downleads to the TV and use an A-B switch to switch between them. If you are willing to suffer that much of a loss, then its far simpler and cheaper to just remove the reflector and make the 8 bay antenna bi-directional.
I guess I left out some important details. I planned on using a seperate down lead and preamp. I just wanted to know if either signal would disrupt the other.
Thanks, mac060 |
#4 | |
An antenna can disrupt another. So you'll have to separate the antennas by at least 30 inches on the mast. .
Mes photos: http://s1140.photobucket.com/albums/n574/BOUVAL-OTA/ |
#5 | |
Thanks for your input.
My hopes were to eliminate the need for another tripod and mast on the roof but that isn't all that important to get the stations wanted. I enjoy reading this forum and learning more about antenna building and the whole system to the set. Keep up the good work. I'll be watching. |
