Bell 6400 HD Receiver. - Canadian TV, Computing and Home Theatre Forums
Old 2012-01-26, 04:58 PM   #1
Pinza
Thumbs up Bell 6400 HD Receiver.
As I said a while ago Bell are going to release a new HD Receiver, the 6400.
ORS = Outright Sale
RCP = Rental Choice Plan
Pinza is offline
Old 2012-01-26, 06:03 PM   #2
Blackloz
Good news. Its about time Bell went HD receivers only. The 4100 should have been gone 2 years ago. I noticed it said under new features that the 6400 has an updated guide. I wonder how exactly is it updated? As all MPEG4 models currently have the same guide anyway?
Blackloz is online now
Old 2012-01-26, 06:12 PM   #3
Pinza
When I get my hands on one I will try to get some screen shots of the Guide.
Pinza is offline
Old 2012-01-26, 06:31 PM   #4
peano
Wow! This is a completely new model from Echostar. Dish Network has nothing like it.
I guess Bell will now support HDMI officially since this box does not have component.
peano is online now
Old 2012-01-26, 07:27 PM   #5
Installer
Pinza do you forsee any problems with the lack of component input from an instalation point of veiw.
"The quality of your question will directly effect the quality of your answer"
Installer is offline
Old 2012-01-26, 07:31 PM   #6
Costa
Old (dvi only equipped TV's) and new equipement (ie. Projection monitors) will not allow audio to be delivered through HDMI of a device. What does a customer do in this case? FL and FR analog for surround sound?
Most of the time, HDMI Splitters will not resolve these issues either. I've seen brand new projectors disable the audio off HDMI because it cannot use it. The only solution was optical.
Anyway, HDMI still has major handshaking issues, I don't think its a right time to make HDMI the only option for HD Video and surround sound.
Everything
Costa is offline
Old 2012-01-26, 08:22 PM   #7
Blackloz
Pick up extra 6131's while you can before all the existing stock is sold off. Even if they are not activated right away. I made this mistake with the 9242 and only bought 1 when I should have got a few extra.
Old 2012-01-26, 08:24 PM   #8
peano
Bell technical support:
"Sorry Mr. Customer that HDMI is not working. Please hook up your 60" plasma with the yellow, red and white connectors. Thank you for calling Bell. Is there anything else I can help with?"
peano is online now
Old 2012-01-27, 08:32 AM   #9
dm_4u
Yikes...now that is one very scary thought.
dm_4u is offline
Old 2012-01-27, 12:41 PM   #10
North_of_Calgary
And yet another receiver with no UHF remote. Sad to see that trend....
North_of_Calgary is offline
Old 2012-01-27, 06:48 PM   #11
Corizzle
Is it just me, or is this essentially a downgrade with the possible exception of whatever the "improved channel guide" is?
Corizzle is offline
Old 2012-01-27, 07:35 PM   #12
JoeLouie
If you really need the component or optical outputs I guess you could consider it a downgrade, but other than that it should do everything else the 6131 does. I'm curious to hear what they have in mind for the 2nd USB port for "future functionality".
More and more newer TVs are coming out without component inputs. A lot of them only have a coax input and 3 or 4 HDMI inputs, plus a dongle to use composite or component. But in my experience the dongles are garbage and I usually recommend picking up an HDMI cable instead.
JoeLouie is offline
Old 2012-01-27, 07:53 PM   #13
Pinza
"Future Functionality", hmmm, sounds like the expansion port on the rear of the 5100, 5800, 5900 models, that was never used.
Pinza is offline
Old 2012-01-28, 12:40 PM   #14
Pinza
They have it covered Peano......
Pinza is offline
Old 2012-01-28, 12:48 PM   #15
scrooloose
I assume this receiver will be sold at the same price as the 4100, i.e. $99? It seems easier to me just to drop the price of the 6131 ( I would prefer Bell stick with identical hardware to what Dish sells, so bugs get caught and fixed quicker).
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub
scrooloose is offline
Tags
6400
