Help - ipod touch won't turn on - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Portable Electronics: Digital Cameras, Camcorders, ebook Readers, iPods, MP3 Players and GPS
Old 2012-01-16, 11:28 PM   #1
reddishapple
Default Help - ipod touch won't turn on
Please help.
My iPod touch just won't turn on! But I know it's charging because I can hear noise that it's charging. But when I press top button the screen is just black? ANone who got the same issue?
reddishapple is offline
Old 2012-01-17, 01:08 AM   #2
NeilN
I had a similar issue with an iPhone 3G. In my case, the screen when activated was really, really dark (easy to mistake for off). Apple replaced it even though it was out of warranty.
Try this:
If the issue persists, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
NeilN is online now
Old 2012-02-15, 04:57 AM   #3
reddishapple
Hello NeilN-thank you so much. After several try and going back and forth to apple (it's out of warranty and they don't wanna replace it, sadly), one day it now turns on. Now what I really want is to backup everything from my device to another computer, in case something bad really happens. Do you think this is possible?
Old 2012-02-15, 08:54 AM   #4
NeilN
As long as iTunes recognizes the iPod is connected, you shouldn't have an issue backing up. I don't know about "everything" as I believe things like game progress are dependent on the developer.
NeilN is online now
Old 2012-02-15, 01:59 PM   #5
jbracing24
I have found dropbox to be an invaluable tool to offload from the touch and iPad pictures and files. The app is good for ios 3.1 and higher. Depending on the level of your ios, iTunes may limit what you can back up. But with dropbox on your mobile devices and computers, its the best thing going. No wonder Google is planning its own version.
jbracing24 is offline
