#16 | |
Your logic makes too much sense and for that reason it will never work. |
#17 |
Just give it 5 years... you'll see
#18 | |
#19 |
Channel 51 is left blank for the future creation of a guard band.
The lower parts of the 700 Mhz will be use for LTE stations with a very high sensitivity. About the 500 Mhz and 600, dont worry IC have no plan to do like the FCC . Canada should have plenty of spectrum for upcoming whitespace technologies ... |
#20 |
insider22, The Canadian government tends to follow American RF policy....so we should be worried.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#21 |
I agree. IC has no plan because it does whatever the FCC does about 2-3 years later. If the FCC claws back more channels for data services, they will want those Canadian channels shut down within 200 miles of the Canada/US border. Since that's where 90% of Canadians live, it's a de facto claw back in Canada as well.
#22 |
That Allentown station was going to build 8 sites, but appears to only have two in operation. There is a station outside of Washington, DC that has an on-channel repeater, but it does not call the pairing a DTS operation.
OTA, it's a beauty way to go! |
#23 |
The FCC can want want it wants, but he current agreement protects the stations up to channel 51. Unless there is something in it for the Canadian Government, don't assume IC will go along with the FCC. Protecting 700 MHz band for Canadian interests is probably what the channel 51 issue is about.
#24 |
The moratorium is a sign of the times and future trends. That is, giving personal communications priority over conventional TV. Canadians and Americans want mobile data. Big communications companies want to provide it. Governments make $billions from auctioning clawed back bandwidth. Besides, using contiguous packet networks for data is more efficient than using fixed broadcast frequencies for sparsely spaced TV stations. We should be doing what the UK is doing which is using centralized repeaters with densely packed TV stations to make TV broadcasting more space efficient. With ATSC, stations can be synchronized to reduce co-channel effects and pack the TV band into a smaller space. With today's technology, here is no reason why several station/network repeaters should be using more than one frequency allocation.
#25 |
From what I've heard, ATSC DTS systems don't work as well as promised. And I think they were only ever designed to cover shaded terrain, so they don't work well out in the open.
#26 |
DTS can't be any worse than having dozens of repeaters on co-channels or adjacent channels to other, totally unrelated stations. That's the situation in Southern Ontario. Here, we have many overlapping network stations which interfere with other overlapping network stations. Even local stations are spread across the entire dial and geographical map. OTA reception is a nightmare and getting worse every year. IC has allowed that with a lot of idiotic channel allocations based on outdated science. The networks and CRTC have thrown a lot of bad business decisions and bureaucratic blunders to make it even worse. It's no wonder most Canadians just give up and pay outrageous prices for TV delivery.
#27 |
why should anyone do anything like the UK? The UK is the UK.
The Geography of the entire UK is roughly twice the size of the state of Pennsylvania. So there isn't really much to cover. Suspect it would be next to impossible for any government controlled entity to pull something like that off in a country the size of Canada or the US.
uhf/vhf combo rotor chimney mount homebrew vhf hi hpf ap-8700 preamp 4way split lg lcd dtt901 pctuner mythtv |
#28 |
I agree with majortom. The UK has a much greater population density, so just because it works for them doesn't mean it will work for us.
As for the idea of putting transmitters on all cell phone towers, that would be extremely expensive in both up up front equipment purchases and maintenance. Replacing the one central transmitter with three or maybe four lower powered transmitters might be feasible, but you would then loose rural reception. A strategy to use low powered UHF transmitters in urban areas and high powered VHF transmitters in rural areas (likely using multicast services) would be necessary, but that would require redesigning the entire band plan from the ground up, which would be a costly exercise for both the government and the stations.
Link to my TVFool results is in my profile Homepage URL. I suggest others do the same. |
#29 | |
It has essentially already been done in the GTA. All transmitters are on a central tower. Even more transmitters would be placed there except for the fact that archaic CTRC regulations prevent it. I am proposing that similar things be done in other cities. That is place all transmitters on a central tower to serve the city and region. It would not only save costs for broadcasters but also make it much easier for consumers since only a single antenna pointed at the closest tower would be required. Channel allocations could be modified in the longer term but that's going to happen anyway as more channels are clawed back and sold to communications companies. Population density and geography have nothing to do with it. If anything, the current system in Canada is counterproductive since it prevents the optimal placement of transmitters in the densest populated locations.
#30 | ||
The problem of atmospheric propagation can be resolved by increasing the distance between transmitters on the same channel. My suggestion was to give each region one VHF channel to be shared by all stations to allow this increased spacing.
