#31 | |
#32 |
The way I understand it, is that the channel has to be carried over the air to require the simsub.
IE. In Edmonton last year CTV had an HD station, but it wasn't OTA. Shaw didn't have to simsub it. Also Calgary already had an OTA CTV HD channel at the time (same time zone), they didn't have to simsub that into Edmonton either. I'm pretty sure the simsub rules are directly tied to the channel being available over the air in your area. The problem with victoria is were right on the cusp of being able to get CTV HD. For the most part you can't, unless you're in a higher elevation and have a good outdoor antenna. Last edited by downbeat; 2012-02-09 at 12:33 PM. Reason: Quote removed |
#33 |
Okay, you appear to be right about the OTA requirement (though I really would like to see the actual CRTC rule). However the law apparently also refers to regions and Victoria is within the Vancouver region. The maps at TV Fool show that you can receive the CTV station there.
I hate to say it but it seems that our national reliance on cable and satellite to deliver TV signals really falls down on this point. There's no incentive for a station like CIVT to provide good service to Vancouver Island if most people are using cable TV over IP or satellite. It therefore becomes a vicious circle. Last edited by downbeat; 2012-02-09 at 12:33 PM. Reason: Quote removed |
#34 |
The way I feel about it is, is the strength of CTV signal in Victoria is pretty weak. You need a fairly high quality outdoor antenna at a higher elevation to pick it up clearly.
It would be nice if the CRTC tighten up the rules a bit. Do some testing, if people can't pick it up with a simple indoor antenna setup, then maybe it shouldn't be considered a broadcast area. Maybe they would install repeaters if the cable companies didn't have to simsub in the area. If i buy a house I might try to install a decent outdoor antenna. Depending where you live in Victoria you can pick up seattle stations. It only works in the higher elevated areas though. Last edited by downbeat; 2012-02-09 at 12:32 PM. Reason: Quote removed |
#35 |
Let's end on this point: An OTA station's contour isn't based on your ability to receive a signal easily, rather a theoretical line at a predetermined signal strength called the "noise limiting bounding contour". So while it's a long shot for most Victoria residents to get Vancouver TV stations, most of those stations' contours lie just outside the Victoria city limits, or they might even cross the city a little. In any case, enough for a simsub to come into effect.
Now … we've gone far off topic — U.S. Super Bowl commercials and their non-availability on Shaw — and the Super Bowl is over for another year, so this thread is closing. However, I encourage you to peruse the Canadian Television Industry forum, where there are plenty of discussion on the pros and (mostly) cons of simsibbing. http://www.digitalhome.ca/forum/forumdisplay.php?f=12 Thanks for your understanding. |
