Does Telus allow data tethering .. - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Telus > Telus Mobility and Koodo Wireless
Old 2011-12-13, 08:13 PM   #1
struts
Default Does Telus allow data tethering ..
and can Motorola Defy be tethered ?
Thanks.
struts is offline
Old 2011-12-13, 10:14 PM   #2
TorontoColin
It depends on your data plan.
The Defy has Android 2.2, so it should come with native tethering capability, but Motorola or Telus might have removed it. You'll find it in the Wireless and Networks menu within the phone's settings.
Rules of the Forum | DHC Help Desk
DHC now supports Tapatalk for mobile devices!
TorontoColin is online now
Old 2011-12-13, 10:20 PM   #3
TKG26
My telus desire has tethering capability since i got it from telus.. I see no reason why Telus would not allow it. You can hit and pass your bandwidth caps way faster this way... Tethering= mo muney fo Telus
Licenced HVAC TECH: "Without seeing your problem i can only offer suggestions, no warranty is included with my advice"
TKG26 is online now
Old 2011-12-14, 10:30 AM   #4
jshel101
The Telus data plans do allow tethering.
http://www.telusmobility.com/en/AB/c...ta/index.shtml
** Additional usage will be charged at 10˘/MB. Cannot combine with any other data plan. Tethering included
jshel101 is offline
Old 2011-12-14, 11:53 AM   #5
struts
Thank you guys for your informatioin.
struts is offline
Old 2011-12-14, 03:04 PM   #6
TorontoColin
Some prepaid plans, if not all of them, disable tethering.
