SA8000 & no sound from recorded shows or live tv - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2004
Old 2004-08-12, 11:17 PM   #1
Lobo
Default SA8000 & no sound from recorded shows or live tv
Having my PVR for almost a week now I've had the chance to play with it some more. Unfortunately with some playing you do find some bugs or quirks. Today when I came home and wanted to watch some recorded shows from the night before I noticed that there was no sound when the show started playing. I hit fast forward three times to get further into the show very quickly and started playing and suddenly there's sound! I rewound (normally) back to the beginning of the show and no sound. I figured it was probably the channel. I fast forwarded (once) and no sound even on the spot that there was sound before. I tried the fast-forward three times trick and there was sound! ??? I hit rewind three times to get the fast speed and then suddenly there's sound at the start of the show.
At this point, having read recommendations on here about rebooting the PVR I decided to do this. After rebooting this fixed the issue and my recorded shows started having sound from the beginning again. However, a few hours later I wanted to watch Nip/Tuck. I put the PVR on the appropriate channel and left it running while I answered the phone. I rewound to the beginning of the show (great feature btw) and started playing but there was no sound! I fast-forwarded three times to get the quickest speed and when I pressed play I got sound again. Grrrr. When I caught up to the show I pressed LIVE to watch the show live but there was no sound as well when doing this. I had to press the rewind button three times and then play so I basically watch the whole show "recorded" or just shortly behind live tv.
To get sound I had to either power off and then on the unit or change channels. Kinda sucks if you wanted to buffer the show. I called Rogers after the show and the rep said that this was the first time he had ever gotten a call about a PVR having issues. I almost chuckled at that because I've read enough on here to know better. Anyways, he rebooted the PVR and of course everything is working fine again. He did say that he would call me back tomorrow to see if the same thing happened and if so he would schedule a service call/visit.
Sooooo, after spending the last hour reading old posts, I didn't really come across people having this kind of an issue. Saw/read many OTHER issues but hopefully those have all been taken care of. So is this or was this an issue earlier this year or could my receiver be a little buggered? Speaking of which is the receiver that I got from them brand new or refurbished? And I think I've seen 57 saying that you should reboot the receiver every now and then, is this really necessary? I don't mind it but I'm curious.
Thanks for any feedback. New to this but still loving the PVR despite some early growing pains.
Lobo
Lobo is offline
Old 2004-08-13, 12:40 AM   #2
Default Re: SA8000 & no sound from recorded shows or live tv
I believe I may have said that the STB may require a reboot once in a while to "fix" any issues you encounter. If it requires reboots more than once a week say, I think there may be something wrong... Do you turn the STB off at night? Does the STB have lots of ventillation room?
57 is offline
Old 2004-08-13, 08:14 AM   #3
Lobo
Yes I power it off every night before going to bed and the unit sits in a cabinet with lots of room above it. I did notice that the unit runs warm compared to satellite receivers.
And as of this morning I haven't encountered the problem again. I'll see how things are tonight.
Lobo
Lobo is offline
Old 2004-08-13, 09:11 AM   #4
salinger
Do you have your 8000 audio going through a home theatre receiver?
I have my audio via the coax output into my surround processor. This means that audio from "live" tv on analogue channels doesn't come through, but if you pause or rewind for a second it will as technically, then you're then watching a digital recording. I don't have the technical knowledge to know exactly why that is, but I know there are many on here who do.
I've not encountered any problems with audio on recorded programs though. If it's a consistent thing, you may well have a faulty box.
salinger is offline
Old 2004-08-13, 09:26 AM   #5
daveharr
salinger, this is odd. My 8000 is outputing audio via the coax output even on live analog TV. I have no idea why - I was very surprised when I found it was working, but the AV receiver is very clearly picking up PCM audio on the coax input on analog channels.
daveharr is offline
Old 2004-08-13, 10:03 AM   #6
The audio from the analogue channels is converted to PCM on newer STBs. On older boxes this was a problem since many A/V receivers didn't have "auto audio sensing" so people would have to constantly switch between the analogue inputs and the digital input when switching between an analogue and digital channel. See the FAQ "if only I'd have known".
http://www.digitalhomecanada.com/for...forum.php?f=57
57 is offline
Old 2004-08-13, 10:33 AM   #7
daveharr
Ah, well that explains it. I hadn't realized that they had made this change on the 8000.
daveharr is offline
Old 2004-08-13, 11:28 AM   #8
Lobo
I do but it's using the RCA outputs and not the digital output. So I'm not running into the other issue you mentioned about no sounds on the analogues.
Lobo
Lobo is offline
